      11-03-2010, 12:16 PM   #1
jumpthewire
jumpthewire's Avatar
Drives: 2007 silver/grey Z4 3.0si
TPMS will not reset
I've read up on this and haven't had any luck.
Had an alignment done and since then the TPMS light ( ! ) will not reset.
1. checked the air pressure and its fine
2. tried holding the ( ! ) button both with the car in 2nd position and running
No luck. It goes off for a few seconds and come right back.
      11-03-2010, 01:03 PM   #2
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
When you turn the car on, hold the button so that it kind of halts a bit, but comes back on. Then drive off around a block or two. Bring it up to some speed, and it should go away. I've found that the car usually needs to be rolled to reset it. If it doesn't work, keep retrying by parking the car, turning off the car and pulling the key out, then re-inserting and starting the car back up, work the button, etc. etc.
Just rinse and repeat until it's gone lol
G'luck!
      11-03-2010, 01:08 PM   #3
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
According to the manual, turn the car on, hold the button until it comes on, roll away until light goes off.
I had this when I first got the car. Started freaking out like WTF! I just got this car!! read the manual, good to go.
      11-03-2010, 01:25 PM   #4
jumpthewire
thanks guys.
i tried the methods above several times/combinations but the light just keeps returning.
spoke with a tech and he said in my situation i should initiate 2 times which resets the whole TPMS. going to give this a go in a few hours.
      11-03-2010, 01:48 PM   #5
scottyD
scottyD's Avatar
Drives: 07 3.0si Coupe
You might have a malfunction in one of the parts of the TPM system - a wheel sensor could have gone bad, for example.
      11-03-2010, 04:02 PM   #6
jumpthewire
another attempt. another failure. going to have to get it looked at. : (
