      10-30-2010, 09:46 AM   #1
jra
Drives: 2005 z4
aftermarket tach?
any ideas on a stealth aftermarket tach location? is it possible to place one in the stock location? btw this will be a functional and needed item for a high reving na project. thanks
      10-30-2010, 04:19 PM   #2
jra
Drives: 2005 z4
Also, can you run the m tach/gas/temp gauge face with correct software?
      10-30-2010, 04:33 PM   #3
O-cha
O-cha's Avatar
218
Drives: Mcoupe
I don't know anyone that passes 9k for an s54, are you doing a swap?
      10-30-2010, 04:57 PM   #4
jra
Drives: 2005 z4
Sorry, I should have stated that this was for a non m
2.5 w/ 3.0 crank, forged pistons/rods, cams, headers, world challenge head
O-cha,
I know you are extremely knowlegable any ideas?
      10-30-2010, 05:14 PM   #5
O-cha
O-cha's Avatar
218
Drives: Mcoupe
O-cha,
M52? What does your tach go up to?
      10-30-2010, 05:21 PM   #6
jra
Drives: 2005 z4
m54, 7000
      10-31-2010, 11:05 AM   #7
O-cha
O-cha's Avatar
218
Drives: Mcoupe
m54, 7000
Hmm well, really can't go much higher then that anyway. Unless the world challenge head has solid lifters.
      10-31-2010, 08:51 PM   #8
jra
Drives: 2005 z4
nope, hydraulic lifters. i guess i was wrong about the higher revs (7500). at least i know that the schrick 272/256 cams are out of the question. thanks for the help
      11-01-2010, 09:02 AM   #9
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Right 7500 is about the max, and that's really pushing it even with better valves. I imagine though if you wanted you could just use the on board computer diagnostic thingy if your car has it (it should) to display the revs whenever you wanted to go that high.
