03-09-2018, 01:33 PM | #1 |
Rep 68
Motor/Trans mounts/Motor bracket bolts?
I have VT motor mounts and think RE Trans. mounts are the best bet for me. If there is anything else out there that I should consider please let me know. Just use the car on the road. Want to put both in together along with replacing the motor bracket bolts that loosen up. Having trouble finding the bolts/washers to buy. Any help would be greatly appreciated.
Thank you again, Mike... |
03-09-2018, 07:56 PM | #2 |
Rep 400
VT said the the OEM transmission mounts are a better design than the RE transmission mounts. As far as your motor mount bolts are concerned, I think that the original grade of bolt will work fine. Here is a thread talking about it.
If you get other ones, two of them are longer than the rest. But I would just make sure your original bolts are tight.
03-09-2018, 08:01 PM | #3 | |
Where Does He Get Those Wonderful Toys?
94
Rep 290
03-09-2018, 08:29 PM | #4 |
Rep 400
If you have the Vibra-technics mounts then that should be enough to keep everything still. The OEM motor mounts allow the engine to twist a lot compared to VT so a stiffer transmission mount would do better. I remember VT saying that the design of the OEM transmission mount is better than RE. All that being said I bought RE mounts at the same time I bought my VT mounts. So I don't know what it's like to run VT and bmw tranny mounts.
03-09-2018, 08:43 PM | #5 |
94
Rep 290
I’m now running VT motor mounts with re tranny mounts. It’s a far better driving experience than when I had the bmw mounts. This is just on my car, as they say results may vary lol!
03-09-2018, 10:09 PM | #7 |
94
Rep 290
The combinations I’ve run so far:
VT motor mounts w/ oem tranny mounts VT mm w/ RE tranny mounts Oem mm w/ oem tranny mounts The combination I have right now is VT mm w/ RE tranny mounts. Best mods I’ve done! |
03-10-2018, 02:45 PM | #8 |
Rep 870
Drives: 2006 BMW Z4M Roadster
I have VT and Rouge trans mounts and like the combo. Did them both at the same time, so can't say if OEM trans would have been better, but it sure didn't make things worse.
McMaster Carr is a good source for the bolts. You'll also need washers. Some use OEM, some use Nord-lock washers. 90854A167 High-Strength Zinc Yellow-Chromate Plated Cap Screw, Class 10.9 Steel, M8 Full Thread, Pitch: 1.25, 25MM LG, packs of 25 90854A172 High-Strength Zinc Yellow-Chromate Plated Cap Screw, Class 10.9 Steel, M8 Full Thread, Pitch: 1.25, 35MM LG, packs of 25 https://www.mcmaster.com/ Salty
Boosted 193.50 |
03-11-2018, 06:39 AM | #9 |
Rep 700
If you were man enough you would have gone for solid mounts
03-11-2018, 06:55 AM | #10 |
Rep 68
Thanks everyone for the input. I hate to buy 25 when I only need 6 of one and 2 of another. If anyone has extras I will buy them. I also am looking for the 8 pan bolts, they are 1 time use right? Too harsh of ride with solids, just looking for improved enjoyment.
Thanks again, Mike... |
03-11-2018, 08:34 AM | #11 | |
Rep 870
Salty
03-11-2018, 10:25 AM | #12 | |
Rep 400
03-11-2018, 09:36 PM | #13 |
Rep 870
I'm old. My testosterone is in decline.
Salty
03-11-2018, 11:18 PM | #14 |
636
Rep 3,124
I think I got mine from ECS:
6 of these 2 of these The latter being "No longer available", but there's the part number so maybe you can find them from another source in small qty. And Nordlocks - 91812A430
03-13-2018, 05:21 AM | #15 |
Rep 68
I found bolts locally in the bright silver finish in 10.9, not sure what type of plating that is ,but think they will work fine. Also found the 8 plate bolts under #31106772199.
03-18-2018, 07:58 AM | #16 |
Rep 68
Got the plate bolts today. Wonder why 1 time use? Also are OEM lock washers for engine mount brackets something special or can they be reused or are they just regular lock washers? Want to get everything right before I start.
Thanks, Mike. |
03-18-2018, 11:14 PM | #17 |
636
Rep 3,124
Plate bolts are "torque to yield".
Once you stretch them once, you don't want to stretch them again. 58 Nm (43 ft*lbs) and then 90° more. Do the ones across the rear first (or so I've read). I doubt there's anything special about the lock washers, but many of us went with the Nordlocks.
04-08-2018, 08:59 PM | #18 |
HammerHead
60
Rep 116
suspension plate bolts torque value
I suspect the torque value (58Nm) is based on the laden weight of the vehicle ( weight on the suspension). My car is on jack stands with the suspension hanging in the air.
Does this effect the torque value or am I just being anal. |
04-08-2018, 11:38 PM | #19 |
636
Rep 3,124
I would think not.
I've had mine off and on at least 4 times while on jack stands. I don't think it would effect the torque value, but might effect the final geometry if the car "bends" while on jack stands with the plate off, and then when you put the plate back on you lock it into that unfavorable geometry, but I think that's pretty anal.
Hedward59.50 |
06-13-2018, 12:29 PM | #21 |
Rep 355
anyone plan on trying these?
http://www.bimmerworld.com/Engine/En...e=news20180613
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
06-13-2018, 10:13 PM | #22 |
636
Rep 3,124
They certainly are colorful, but I couldn't help but wonder if tuning the engine mounts was taking the concept of tuning just a little too far.
