      01-17-2015, 12:52 PM   #1
SwissArmy
Why so serious?
SwissArmy's Avatar
Drives: BMW Z4; BMW X5; BMW 733
HELP! Passenger side HID does not work
Hey guys,
My passenger side HID does not work. The DRL does.
I've tried new bulbs on both sides. I've also swapped the ignitors around and it works on the driver side but not the passenger side. So, the bulbs and the ignitor are ok.
Checked all the fuses behind the glove box, all lighting fuses are good.
What could be the issue?
Thanks
      01-17-2015, 02:40 PM   #2
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
Originally Posted by SwissArmy View Post
Hey guys,
I've tried new bulbs on both sides. I've also swapped the ballasts around and it works on the driver side but not the passenger side. So, the bulbs and the ballast are ok.
Thanks
Check the fuses. I believe left and right side are fused separately....
Top Down 365
      01-17-2015, 02:42 PM   #3
SwissArmy
Why so serious?
SwissArmy's Avatar
Thanks. Which fuse am I looking at? 59? 60? The regular lights work on both sides. The HID does not work on just the passenger side...
      01-17-2015, 05:04 PM   #4
dc_wright
dc_wright's Avatar
249
Need to check 14, 23, 59, and 60.
Top Down 365
      01-17-2015, 09:30 PM   #5
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
its your ignitor
instagram: @ dubsesd
      01-17-2015, 09:31 PM   #6
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
silver box that hold your bulbs
      01-18-2015, 05:55 AM   #7
SwissArmy
Why so serious?
SwissArmy's Avatar
This thing? I swapped them around to the other side and it works on that side.
So this must not be the cause
      01-18-2015, 05:56 AM   #8
SwissArmy
Why so serious?
SwissArmy's Avatar
Thanks, will check it out today. Damn dealerships are closed on Sundays
      01-18-2015, 06:34 AM   #9
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
Ok. You mentioned u swapped the ballast not the ignitor
      01-18-2015, 06:44 AM   #10
SwissArmy
Why so serious?
SwissArmy's Avatar
My mistake. I'll correct the OP
      01-18-2015, 07:43 AM   #11
SwissArmy
Why so serious?
SwissArmy's Avatar
Checked all the fuses, all fuses are good...I wonder what could be the cause! Updated OP
      01-18-2015, 09:11 AM   #12
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Try checking the ground connection for the lights. Here is a pic from bmw planet.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      01-18-2015, 09:39 AM   #13
SwissArmy
Why so serious?
SwissArmy's Avatar
Thanks bignosejim. I'll check that out. I will also check Part 3 Below to see if the other end is secure and not cut
http://www.ecstuning.com/Search/Wiring/ES165766/
      01-18-2015, 10:35 AM   #14
bignosejim
bignosejim's Avatar
You can also check for continuity between pin 34 and ground (the right headlight) at the headlight switch with the switch to ON and see if you get the same reading as pin 7 to ground (the left headlight). If you don't have continuity on the right and do have it on the left, you might need a new light switch.
Go to BMW Planet.com for a drawing of the circuit. It's under complete vehicle/ body/ lighting/ low beam light.
Can't cut and paste this one right now.
      01-18-2015, 10:47 AM   #15
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
what you could do is swap the headlight and see if power from the opposite side fires up the headlights. it could be the ballast now
      01-18-2015, 06:55 PM   #16
SwissArmy
Why so serious?
SwissArmy's Avatar
Will check that out tomorrow.
Thanks. Will try this and report back
