12-08-2014, 11:46 AM | #1 |
Rep 2
Two different headlights
I have a 03 3.0i z4 and I believe before I got it that it was in a small front end collision who ever fixed it made a mess. I have xenon lights in the passenger side but the driver side has halogen. I would like to install the spyder halo headlights (which is a plug and play set) but I'm not sure how to install them since the plugs for xenon lights and halogen lights are different.
12-24-2014, 03:35 PM | #2 | |
I plead the 5th.
523
Rep 1,519
If you enter the last 7 digits of your VIN here -> http://realoem.com/bmw/select.do and you go to the correct section, it will tell you which lights your car had from the factory. If you aren't sure, post up the last 7 digits here and I'm sure someone can pull it up for you. Knowing which it had from the factory may give you a lead on ease of replacement.
-Matt
