      02-25-2018, 05:57 AM   #1
Shlabby
Shlabby's Avatar
Drives: Z4
Storage question
Hello all.
I unfortunately my car has been in storage due to the winter.
Hopefully I can get her out to drive in a month or so.
In the mean time I want to put a battery tender on it.
Do I remove the battery or can I put it in a closed trunk?
I want to keep the car cover on it.
Thanks for the help.
      02-25-2018, 06:34 AM   #2
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Just connect the battery tender to the (+) and (-) jump posts under the hood in the engine compartment.
      02-26-2018, 07:42 AM   #3
Slalom
Slalom's Avatar
Drives: 04 Z4, 18 X3 M40i
2004 Z4  [0.00]
2018 BMW X3 M40i  [10.00]
I have used a battery tender each winter since 2005. I have one of the BMW units that connects to the cigarette lighter. Fortunately the E85 cigarette lighter was designed for this and does not go to sleep after the car shuts down.
      02-26-2018, 01:05 PM   #4
Huz-Z
Huz-Z's Avatar
I connect mine to the battery terminals, gently close the trunk, cover and count the days until spring.
Huz-Z
      02-26-2018, 02:46 PM   #5
Roadroach
Roadroach's Avatar
165
Drives: 2006 Z4 3.0si coupe w/stick
Originally Posted by Huz-Z View Post
......and count the days until spring.
Heh. Central Texas for the win.
2006 Z4 coupe - with HOMELINK!
1966 Mustang GT fastback (too many mods to list)
2015 335i GT
2014 981 Cayman S manual
      02-26-2018, 06:29 PM   #6
Huz-Z
Huz-Z's Avatar
My wife works with a lot of very fine folks in her company’s Houston office and if things weren’t so busy for her we might be visiting there right now. Would love to see the place some time.
In the meantime, spring is worth the wait !
http://www.zpost.com/forums/album.ph...ictureid=37835
Huz-Z
      03-04-2018, 03:03 PM   #7
Shlabby
Shlabby's Avatar
Drives: Z4
My battery power tender has an end I can hard wire in under the hood.
Unfortunately the positive looks to big to be able to put the end on it.
Any suggestions or is there an alternative spot for the positive?
Thanks for any help.
      03-04-2018, 06:43 PM   #8
3798j
3798j's Avatar
11351
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
Under the positive jump post is a threaded stud...that's where I attached mine. I needed to splice a longer (about 18") length of wire because I wanted it to run to the base of the windshield. There's a negative ground stud on the firewall.
      03-11-2018, 02:29 PM   #9
Shlabby
Shlabby's Avatar
Drives: Z4
Thank you 3798j (if that is your real name).
Nice clean install.
3798j11350.50
