      01-21-2016, 05:35 PM   #1
IN10SS
Drives: 2007 Z4M Roadster
Plexy windscreen $70
I have this nice Plexiglas windscreen for sale. It has the upgraded clear straps to hold it in place, making for a nearly invisible install if you position the straps right. This greatly reduces buffeting at hwy speeds and lengthens top down season. It's held on with Velcro and does no damage. $70 shipped. Sold, thanks.
2007 Z4M Stromung exhaust, CDV delete, Vibra-Technics engine mounts, Rogue Engineering Transmission mounts, Auto Solutions SSK, Bimmerworld spherical RTAB's, BMW STB, SuperPro FCAB's, SS brake lines, Eibach springs, Beyern Wheels, 245/275 Michelin PSS.
2008 135i Barely running. Work in progress.
      02-09-2016, 10:26 PM   #2
IN10SS
I know it's a little slow this time of year, but no other single item will help get you back on the road cruising with the top down sooner than one of these. This really increases the protected air pocket, dramatically reduces buffeting, and helps keep you warmer. This adds about a month to either end of roadster season. It's practically invisible, doesn't interfere with the top, and you can take it off in seconds if you get too hot and put it in the trunk. If you have a roadster and don't have something similar, you're missing out!
