10-26-2011, 06:48 PM | #1 |
Accidentally in BMW
15
Rep 221
CEL solution? Cat Sim... Micro Cat
I know there have been some discussions re O-Cha's (?) cat sim (I haven't seen details, but remain interested...).
I have also seen some DIY versions on other forums that simply involve lengthening the bung to take the secondary O2 sensor away from the exhaust flow, reducing its exposure, and thereby "simulating" a cat. This method seems a little unpredictable to me - but it probably works for some of the people some of the time. Of course, there are DIY articles here and elsewhere that involve putting fully functional bungs after the secondary cats... but I was looking for an alternative that might remove the need for cats of any description. I just ran across this site that sells different versions of extensions and a "mini-cat", combining the extension with a wee little piece of catalytic material to satisfy the secondary O2 sensor/ECU partnership. It seems pretty slick to the uninitiated (like me) ... I could install either an AA or similar header with all the bungs, or add a couple of downstream bungs to a euro header... and put this little device between the secondary bung and the sensor. Old news? Comments? Off road, competitive use only, of course.... http://www.bigdaddiesgarage.com/?gcl...FRBkhwod-ShL9A Cheers. Last edited by EenyBear; 10-26-2011 at 07:01 PM.. |
10-26-2011, 07:38 PM | #2 | |
Rep 1,031
Interesting ... I wonder if it really works and longevity of the product. I remember reading the O-cha fix might work for 300-500miles and then foul up.
http://www.m3forum.net/m3forum/showt...light=defouler Last edited by Mirko; 10-26-2011 at 07:58 PM.. |
10-27-2011, 03:42 AM | #3 |
Rep 2,782
There's another way that works on the E9x involving soldering in a couple of resistors. I haven't looked into it enough to see if it would work for the Z4M, but it's what I was going to try first. I would probably use a potentiometer so that I could fine tune the readings.
Link
10-27-2011, 08:49 AM | #4 | |
Rep 1,031
10-27-2011, 04:10 PM | #5 |
Rep 2,782
With potentiometers you can vary the resistance, so you can tweak it to your car's needs. If you have the tools you should be able to measure the exact resistance required. However, I'm in the same boat as far as not wanting to splice into the wiring loom. I haven't looked into it enough to figure out which wires to use, or if it's even feasible.
