      10-28-2010, 03:47 PM   #1
bmwtmx
bmwtmx's Avatar
111
Drives: 2008 BMW M3
Which M3 Wheels Fit Z4MC?
Do any e46 M3 wheels fit the Z4MC including 18" and 19" sizes? Can you run rear 18" wheels on the front?
      10-28-2010, 04:11 PM   #2
The HACK
The HACK's Avatar
1821
All of them. No you can't run the rear 18s up front, not without significant camber AND some fender rolling...Even then it's still no guarantee that it'll fit.
      10-28-2010, 04:49 PM   #3
bmwtmx
bmwtmx's Avatar
111
Drives: 2008 BMW M3
Ok so the stock E46 18" wheels are 8 and 9 inches wide. Trying to see largest tire size I can run if I were to use these as track wheels. Might not make sense as I want 8.5 and 9.5 minimum but I can get a set so cheap it's hard to ignore.
      10-28-2010, 05:02 PM   #4
Endless619
DHS
Endless619's Avatar
I had my E46 M3 18 inch wheels on my Z4M for a while with lowering springs and had no issues with rubbing.
However, I did have my rear E46 M3 wheels on the front and it fit fine at stock height before I lowered it. Just need to go with a smaller tire and it will fit.
What are you trying to do?
2023 BMW M4
2016 X3
      10-29-2010, 09:33 AM   #5
bmwtmx
bmwtmx's Avatar
111
Drives: 2008 BMW M3
Just trying to get a reasonable set of track wheels/tires. want to run perhaps 245 or 255 front and 275 rear on 9" wheels. thought the E46 setup might work but they are 8 and 9 inches wide so I am doubt I will buy 2 sets of wheels to accomplish this.
      10-30-2010, 10:39 AM   #6
pal
pal's Avatar
433
Drives: Z4 M Coupe
These do and look quite good I might add ...
      10-30-2010, 10:56 AM   #7
jmillet
jmillet's Avatar
64
My track setup is E46 M3 Style 67 wheels (8X18ET47 front and 9X18ET26 rear) with Toyo R888 tires (245/40-18 front and 255/35-18 rear). I install 10mm spacers in front to allow clearance of the TCK coil over struts.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      11-01-2010, 10:39 PM   #8
bojinns
Drives: 2007 E86
+1..all e46 m offset is very close to z4m offset..
      11-02-2010, 02:38 AM   #9
jmillet
jmillet's Avatar
64
E85/6 Z4M wheels are Style 224, 8X18ET42 front and 9X19ET30 rear.
Jim Millet
      11-03-2010, 12:14 AM   #10
epbrown
epbrown's Avatar
Drives: BMW M Coupe, Porsche Boxster S
Do the E46 M3 17" winters work on the Z4M though? I've wondered, as the offset would work but they might not clear our brakes, which are from the CSL...
      11-04-2010, 10:38 AM   #11
BlackMoupe
Mouper
BlackMoupe's Avatar
Drives: _____
Not to thread jack but...
Do E92 rims fit? Idk what the style # is but they're similar to 67
      11-04-2010, 04:46 PM   #12
bojinns
Drives: 2007 E86
The best way to find out what feels fit your ride is to know the offset of your oem wheels. Other factors are taken into consideration as well such as width and size. Which is another topic. Do a search
This link will give you offset info of your ride: http://www.realoem.com its a real good source of info for parts too.
      12-23-2010, 05:21 PM   #13
fitchesbass
Drives: BMW
19" OEM E46 M3 wheels on stock suspension, stock E46 M3 tire sizes. No issues. Suspension look a little jacked up because I literally just backed it out of the garage and it hadn't settled after being on jackstands.
Compared to the stock OEM Z4M wheels:
911 Carrera project car
Previous:
E92 M3 ZHP - Sold
E86 Z4M - Sold
E36 M3 - Sold
      12-23-2010, 05:38 PM   #14
Endless619
DHS
Endless619's Avatar
E92 19's and 18's fit fine...and I am lowered...
2023 BMW M4
2016 X3
      12-24-2010, 04:24 AM   #15
Jbs
The Photographer
Jbs's Avatar
Drives: 07 Z4MC BSM/Black extended
Will the E92 Competition Package rims fit the Z4MC???
John Batte Photography / Flickr / Facebook
2007 ///M Coupe BSM/Black Extended/Loaded | RPi GT Exhaust w/custom gloss black tips | KW V3 | Michelin PSS 245/265 | Pinnacle F1 Tint 35% | ZHP Shift Knob
      08-28-2012, 12:04 PM   #16
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
style 67 is best way to go...had them before....they rock. way better looking in person.
      08-28-2012, 12:48 PM   #17
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
Yep, they fit perfectly.
SOLD: 2008 M Coupe
      08-28-2012, 05:36 PM   #18
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
For the E92 Competition wheels with stock suspension settings the fronts will rub for sure, especially during hard cornering. Unless you are running OEM tire widths which would look pretty stretched.
      08-29-2012, 12:59 AM   #19
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
871
Drives: 635/1815, X3M Comp
I picked up a set of 359m OEM ZCP wheels a few weeks ago.
I'm a little worried now after reading Daemonblitz's response.
What sort of work is needed to avoid rubbing w/ in the front w/ the 359m wheels?
I'm looking 245s front / 275s rear
I wish Chamberlain would chime in on this considering he has some 359m ZCPs on his car.
      08-29-2012, 06:46 AM   #20
Beedub
i agree, the 18s however and seem to work well.
