      09-01-2013, 10:41 AM   #1
pal
pal's Avatar
433
Drives: Z4 M Coupe
Z4M S54: Rod bearings replaced again ...
I had replaced the rod bearings at 59K miles back in Sep/Oct of 2011 and the last couple of reports of my oil had lead reading that started to jump again. I have done 37 track days since the last bearing change and the car now has 81K+ miles on it (and a total of over 80 track days).
One more point to note is that the last 2 years I have been driving the car better and improving my lap times - this means more full throttle time and more high rpm usage.
59K Rod Bearings Replacement
Since I have multiple upcoming track days including one tomorrow at Watkins Glen, I did not want to risk the motor and decided to get them replaced again. RRT in Dulles, VA were nice enough to come in on Sat morning on Labor Day weekend no less to do the work for me. They even stayed late on Fri night until I got to there shop so they could get my car in and drain the oil and park it inside.
It appears there was enough wear esp on cyl 3 upper bearing that was down to bare metal and I could feel it rough and scratchy with my nails. Cyl 4 top has a little point like that as well so it may be starting to go too.
There is some offset (on the sides) wear on some bearings but there was some on my first set as well. I am guessing its just a manufacturing variance on my motor with how the rods sit on the bearings and some could be possible variance in thickness of the coating on the bearings I had in the car.
I went with OE bearings (no coating) and ARP bolts this time as that is what RRT had in stock.
RRT recommended I switch to Motul 300V Competition 15w50 oil as they have seen better bearing life with it so that's my new oil for now.
      09-01-2013, 10:54 AM   #2
dorifto88
Drives: 88 Nissan Pathfinder
i am speechless.
could you by any chance share your last few oil change reports? id like to see the increase in lead levels. i am sorry you had to go through this ordeal, again.
      09-01-2013, 11:01 AM   #3
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Wow...so the treated bearings didn't do much to decrease the wear?
      09-01-2013, 11:34 AM   #4
seank
enthusiast
seank's Avatar
48
What have you done to put more oil on them. Have you upgraded the oil pump?
      09-01-2013, 01:29 PM   #5
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Maybe with your more aggressive lap times, a dry sump conversion should be considered, Pal.
http://www.vacmotorsports.com/catalo...mp-kit-s54.htm
      09-01-2013, 03:23 PM   #6
seank
enthusiast
seank's Avatar
48
http://www.vacmotorsports.com/catalo...n-oil-pump.htm
      09-01-2013, 05:42 PM   #7
chickdr
Drives: 2006 M Roadster
Wow- the dry sump kit costs over $6K???. I think I would just keep doing bearings every 40K.
      09-01-2013, 07:46 PM   #8
beta
Originally Posted by seank View Post
For $500 this might be a good option to try out before a 6k dry sump upgrade.
      09-01-2013, 08:21 PM   #9
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
...anyone here install one yet?
      09-01-2013, 08:32 PM   #10
pal
pal's Avatar
433
Drives: Z4 M Coupe
I am at Watkins Glen with Chin so will upload and post last 2 reports. Lead was 9 and 15 ppm on the last two and ones before are here. For reference, 60, 514mls was the first report after first set of bearings.
http://dertt.fotki.com/m-coupe/maintenance
The coating seems to have done its job and worn away first. Its not supposed to be a bullet proof solution but an additional layer of protection and sort of a sacrificial layer.
RRT recommended using Motul 300V Comp 15w50 oil. I am guessing this is not only a bit thinner and hence possibly will get in there but being a comp oil, better maintain its stability at high temps.
I need to do these myself going forward every 20K miles or 30-35 track days going forward.
      09-01-2013, 09:22 PM   #11
Shipkiller
Shipkiller's Avatar
Drives: Me
This might be a good upgrade, but I would think if you do not change out the Constant Pressure Valve (CPV) to an upgraded one (not seen one offered), which I think keeps the oil pressure regulated to 58psi (not sure of that value), a higher flowing pump will not make a difference. Could be wrong though.
      09-01-2013, 11:22 PM   #12
seank
enthusiast
seank's Avatar
48
In an s14. On a track e30m3, you go to larger coated bearings and upgrade the oil pump to flow more oil. The result is better flow. The problem with increasing the oil viscosity, which is what most want to do, is it does not flow as well, so even though it is better to higher temps, it doesn't coat as well. When you upgrade the s14, you are able to run thinner oils, run cooler, and increase oil flow.
Just a thought. I would find out whose setting track records with an s54 and ask them what they have done. Most club guys aren't replacing their motors every year.
      09-01-2013, 11:22 PM   #13
chickdr
In your case the number of track days seems to be the key. You went 60k on the original set, but only had 37 track days. You did over 40 track days in the last 20K miles so they wore out in less miles. You can use the track days like the cars service indicator uses gallons of gas...
      09-01-2013, 11:33 PM   #14
seank
enthusiast
seank's Avatar
48
Originally Posted by chickdr View Post
[/B]
They should last longer. Track cars at the club level and fast drivers last 4 years or 80 track days
      09-02-2013, 06:20 AM   #15
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
can i ask what it costs to replace the Rod Bearings? all up?
Powered by
      09-02-2013, 10:15 AM   #16
pungo
pungo's Avatar
So I wonder what the rod bearings look like on some of these cars with FI in the 445-525 hp range?
      09-02-2013, 10:17 AM   #17
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
& the torque.
      09-02-2013, 12:05 PM   #18
Shipkiller
Shipkiller's Avatar
Drives: Me
Depends on who does it. It cost me $1600.
      09-03-2013, 12:36 AM   #19
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Shippy, is that you helping out or dropping it off and picking it up?
Powered by
      09-03-2013, 05:19 AM   #20
Shipkiller
Shipkiller's Avatar
Drives: Me
Dropped the car off, picked it up a couple of days later.
http://www.zpost.com/forums/showthre...ght=shipkiller
      09-03-2013, 06:56 AM   #21
kennyfrc
kennyfrc's Avatar
18
Drives: 2008 Z4MC
The Motul 300V Comp doesn't look spectacular on paper. Very interested to see a UOA on it.
Daily: 2010 Tacoma Double Cab
      09-03-2013, 07:09 AM   #22
kennyfrc
kennyfrc's Avatar
18
Drives: 2008 Z4MC
This engine only has 60LB of oil pressure for 8K RPM max.
