      04-15-2012, 07:16 PM   #1
DataStream18
Drives: 2003 ESS TS1 Z4
Top is catching on something. . .
When its hot out my top catches on something, Im thinking its the center locking mount. Not the whole top its the rubber for the glass at the center. I'm trying to figure out why?
(Click on picture for vid)
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit.
      04-15-2012, 10:34 PM   #2
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
This a designed issue. It did the same when I had my 04 Z4. It leaves a fang mark on the top. I took it to dealer but they can't do any adjustments to prevent it. There were some discussion on this on one of the forum.
