04-12-2012, 02:09 AM | #23 | |
701
04-12-2012, 05:32 AM | #24 |
Rep 2,138
Drives: Me
I did take the completely dead key apart last night. This morning I attempted to use just that key (no internal electronics) to start the car with the working key sitting on the center console by the shifter. This was to see just what would happen. No start.
I 'assume' that when you insert the key in the ignition, the inductive coupling now allows the certain interlocks/blocks to be removed internally to the key and the code is transmitted to the antenna located in or around the ignition assembly. I am also going to assume this is a coded pulse train but the only way I could find out is to have a spectrum analyzer present (like a Wavetek or similar) to look at the transmission from the key to ignition assembly. I do know that it is very low power signal centered at 317MHz. Hopefully my new keys will be here today or tomorrow. I want to get this issue fixed since I am on a plane to San Diego on Sunday. Have to be there for two or three weeks. Last edited by Shipkiller; 04-12-2012 at 05:39 AM.. |
04-12-2012, 09:37 AM | #25 | |
Rep 2,782
04-12-2012, 09:42 AM | #26 | |
Rep 2,782
04-12-2012, 10:35 AM | #27 |
Rep 4,057
We have 2001 and 2009 Honda Accords and for both cars, the keys have immobilizer circuits. That means that you can go to a hardware store and have a key cut, but you can only open the mechanical door locks with it. It won't work in the ignition and it won't let you start the car.
Presumably, the Z4 keys do something similar. My local SA told me that they include a memory feature that talks to the car's computer and records service information. So, if your car is asking for service, the SA can use just the key to determine if that is an oil change, coolant flush, or some other maintenance item.
Huz-Z
04-12-2012, 11:25 AM | #28 | ||
Rep 2,138
Drives: Me
The EWS: http://www.shipkiller.com/Electronic...m_EWS_3.3.html Quote:
04-12-2012, 11:39 AM | #29 |
Rep 1,989
When I used to take mine into the dealer the SA would take my key and lay it inside a round device attached to her computer. Not sure what it got from my key but she did this every time I went in.
04-12-2012, 12:19 PM | #30 |
Rep 4,365
Of course, when the first key stopped honking when it was bit, the backup toy was pulled out cause it's honker was still good.
04-12-2012, 01:07 PM | #31 |
Rep 4,057
My SA did the same thing but he did seem to have difficulty getting the detailed information he expected to see. As Ship suggests, its likely that this little feature works much better on the E89s.
Huz-Z
04-16-2012, 01:51 PM | #32 |
Accountant, 1st Class
Rep 237
Drives: 2006 Z4 3.0si Roadster, Black
And while you're in there, why don't you just turbocharge the flux capacitor too?
"I was always told if you drive a roadster with the roof up, the storm outside better have a name", Mikedav, UK
04-17-2012, 08:56 PM | #33 |
Accidentally in BMW
15
Rep 221
Hi,
He missed you. The keys were full of "people smells" that reminded him of you and he was communing with the memory. Darn inconvenient tho'... I get it. Nothing happens without a reason. This is a great opportunity to try one of these little beauties for yourself: http://www.ebay.com/sch/i.html?_from...w=BMW+flip+key Choose wisely but the quality is generally very high and it feels better in your pocket. Easy swap-out. Cheers, |
