      02-27-2017, 04:33 AM   #1
SwissArmy
Why so serious?
SwissArmy's Avatar
Z4 No-Drill License Plate Mount?
Hello!
I've recently purchased the 1M style bumper for my E85 3.0i.
On my stock bumper, I had the tow hook license plate mount.
On this bumper, here is no tow hook hole for a tow hook mount. Other than drilling a tow hook hole, or drilling holes in general, can someone suggest a no-drill license plate mount that holds steady and sturdy?
Thanks in advance.
      02-27-2017, 04:24 PM   #2
crawlin
Drives: BMW Z4 M
look on ebay for hideaway front plate. it mounts under your bumper and comes out right on the bottom wherever you mount it and it slides under to hide during car shows and stuff its pretty slick. Its like $50
SwissArmy140.50
      02-27-2017, 04:37 PM   #3
Don L
Don L's Avatar
Drives: 2006 Z4 3.0si coupe
Take a look at Skene Design license plate mount. I used it on my 06 3.0si.
Don
SwissArmy140.50
      03-02-2017, 10:02 PM   #4
SwissArmy
Why so serious?
SwissArmy's Avatar
Looks great! However, my car is sitting low on coilovers. It might be an issue if it's mounted under the bumper. Thank you
Don
Thanks Don, but the Skene design would still require me to drill the bumper. I don't mind too much of drilling UNDER the bumper, but I am trying to avoid drilling altogether.
I wonder if the license plate can sit within that giant lower grill...hmmm I should do some measurements and use some zip ties
      03-02-2017, 10:14 PM   #5
3002 tii
3002 tii's Avatar
2282
I used a low profile frame with rare earth magnets, worked great
Follow for latest mods
SwissArmy140.50
      03-04-2017, 06:39 AM   #6
SwissArmy
Why so serious?
SwissArmy's Avatar
That sounds great. Do they leave "dents" in the bumper (being so strong, and all)
      03-04-2017, 09:57 AM   #7
pungo
pungo's Avatar
I would be cautious about blocking airflow though the lower grill, it's not just there for looks, it has a purpose, cooling the radiator and condenser.
I also recommend the rare earth magnets for a no drill method.
SwissArmy140.50
      03-04-2017, 12:25 PM   #8
3002 tii
3002 tii's Avatar
2282
No but I'll take a video so you can see what I did. Stole the idea from dekaliber but basically...
1. Get a metal plate frame like this or make one with L brackets. If you buy the amazon one, spend a few extra bucks to replace the screws with stainless steel ones and rough the frame up with sandpaper and do 2 coats of spray paint to prevent rust.
2. Buy some rare earth magnets for both bumper and plate frame. Trick is to find the biggest diameter that will fit behind the bumper. I got mine from eBay. The ones that go on the plate frame will be smaller.
3. Apply double sided tape on magnets that will go behind bumper. Pop off kidney grills and stick magnets to bumper support bar.
4. Apply smaller magnet to plate frame and then cover the magnet with duct tape to prevent scratches.
You should read the write up though, it has good tips on how to drop the magnets for exact placement. I think I chose a strength of 25lbs... magnets stay put at triple digits but not impossible to remove neither.
SwissArmy140.50
      03-04-2017, 07:07 PM   #9
SwissArmy
Why so serious?
SwissArmy's Avatar
You should the write up though, it has good tips on how to drop the magnets for exact placement. I think I chose a strength of 25lbs... magnets stay in at triple digits but not impossible to remove neither.
OMG this is EXACTLY what I'm looking for! Thank you so so so much for making and uploading that video!
Thank you everyone! Thank you 3002 tii and dekaliber!
      03-04-2017, 08:22 PM   #10
3002 tii
3002 tii's Avatar
2282
No problem! Also for what it's worth I used a zip tie at one point to tether to lower grills.
SwissArmy140.50
      03-07-2017, 07:38 PM   #11
angelr
Drives: 07 aw/ir m coupe, 2013 S4
I have one that threads into the front tow hook hole and has a bracket that attaches to that....never use it though
      03-08-2017, 05:19 PM   #12
SwissArmy
Why so serious?
SwissArmy's Avatar
Thanks angelr. That is what I currently have on my stock bumper. However, as the original post stated, the 1M style bumper for the E85 does not come with a hole for the to hook.
      03-10-2017, 02:55 AM   #13
crawlin
Drives: BMW Z4 M
Yea I hear ya, I got sick of the coil over ride and honestly it doesn't sit that low but it seems you got your fix!
SwissArmy140.50
      04-04-2017, 02:56 PM   #14
Harrison256
Drives: 2006 BMW Z4 3.0si
Where did you pick up that bumper and about how much? I'm thinking of going that route
      04-04-2017, 10:05 PM   #15
SwissArmy
Why so serious?
SwissArmy's Avatar
Traded a set of BMW 108's (refinished) for the bumper here, locally. But I see these bumpers listed on eBay and several other sites.
