      06-08-2011, 02:39 PM   #1
yvel26
yvel26's Avatar
Drives: BMW Z4 M Roadster
ECU re-programming
Hello,
Anyone did a re-programming of the ecu to get some more horsepower?
If so what gain did you get and is it worth it?
Here in belgium you get a 22 hp and 22 Nm torque gain.
I know you can get much more gains from superchargers etc ... but they are illegal here and have to be removed with each technical control.
And ecu re-programming isn't visible at technical control.
Thx Yves
      06-08-2011, 02:40 PM   #2
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Superchargers are illegal? ouch
      06-08-2011, 02:50 PM   #3
yvel26
yvel26's Avatar
If installed afterwards yes (not factory installed)
      06-08-2011, 03:56 PM   #4
Arxangel
Arxangel's Avatar
Bulgaria
16
Drives: 2006 Z4 3.0si Coupe
2006 Z4 3.0si  [8.50]
Interesting, I never knew there could be legislation like this anywhere. This must kill the after market turbo business in Belgium.
      06-08-2011, 04:08 PM   #5
ZStig
279
If you're going to upgrade the car, the biggest gains are from a catless european header (I assume that is already on your car), then 4.10 geared differential, and then a tune. If money allows, you can also get cams, and ess has a specific tune for that
      06-08-2011, 05:24 PM   #6
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
Rear mounted Turbo....there is a lot of space for it in the axle exhaust area...very doable....
      06-09-2011, 12:34 AM   #7
SV Concepts II
SV Concepts II's Avatar
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
Hello,
Thx Yves
If you want a really good tune, you can send your ECU in to Active Autowerke in Florida. They have a really good tune that produces some great horsepower. You can read the testimonial of this customers experience with the tune here.
      06-09-2011, 02:58 AM   #8
Robmaster
Robmaster's Avatar
Switzerland
151
Drives: 2010 E82 135, 2005 E87 130i
yeah, right... so why do BMW in the E46 M3 CSL not just a chip tuning to become 360PS?
      06-09-2011, 07:24 AM   #9
trsbmw
deft danish devil
Drives: BSM E86 M-Cp, LMB 335d M-Sport
2007 Z4 M Coupe  [0.00]
Are engine swaps illegal? If not, go for the S85. (If money is no object of course)
