05-28-2011, 03:52 PM | #1 |
Rep 10,309
Drives: A///MERICAN!!!
Z4M Brake Pads
I know this DIY already exists but myself and wassup61 took these pics a few months back and since there are none of the front calipers I figured I'd finally throw this together once I had some spare time to supplement the original DIY.
Refer to the first DIY if you need a reference to get your car in the air and wheels off. Work under your car at your own risk. Use a flatblade screwdriver to pry this clip off Remove dustcaps Remove caliper slide pins with an allen key Use a clamp to compress piston to facilitate caliper reinstallation Can you guess which is which? New pads go in pretty straightforward. Clip inserts into the piston (inside pad). Outside pad slides in Rears are very similar. Right rear wear sensor Removing slide pin. V3's shock has an external reservoir which makes this a PITA Don't forget about this clip Some info on proper bedding here |
05-28-2011, 11:26 PM | #2 |
Rep 2,460
FYI if anyone buys monroe brake pads the rear clips will some how cut into the rear wheel hubs....why i put monroe brakes on? i dont know...but never go cheap...
but yeah awesome wrote up |
05-29-2011, 05:26 PM | #3 |
M = Midlife Crisis
65
Rep 2,006
FYI - Monroe does not make Brake Friction; they sell the brand to those that do...
2006 Z4MC - #LL93158
05-29-2011, 07:28 PM | #4 |
Rep 10,309
the pads coming off are OEM and the ones going on are Axxis Ultimate
05-29-2011, 07:34 PM | #5 |
M = Midlife Crisis
65
Rep 2,006
Stoptech and Cool Carbon make friction material applied to OE backing plates that is superior to OE IMO.
05-29-2011, 09:01 PM | #6 |
Rep 10,309
Yea I considered the Stoptechs, but for the price went with the Axxis.
