01-16-2013, 10:26 PM | #67 |
Rep 1,107
Which app did you use? There is one called RTA that I'm thinking of using to do as you have (think I've got a mid-bass hole, which can be typical of an MS-8). Also, if it's not too much trouble, what is the procedure you used? I'm a total beginner on using an analyzer to tune. Much appreciated.
01-17-2013, 03:50 AM | #68 | |
Rep 32
01-17-2013, 09:38 PM | #69 | |
Rep 704
Drives: '08 MC
give it a whirl. Mousitch also posted on the forum about some beginner issues he had, but he ended up getting it done too... perhaps dig up his thread, 'coding drivng me nuts', or somethin like that. good luck, keep us posted.
01-17-2013, 10:57 PM | #70 | |
Rep 820
Drives: 2007 Z4MR silver grey
80hz = flat 200hz = -1 500hz = -4 1000hz = flat 2000hz = flat 5000hz = flat 12000hz = flat to +2 Those are for stock speakers (Carver system). I have JL Audio Silk Dome Tweeters in there now, and they are more efficient than the factory tweets, so I had to dial back the 5000hz and 12000hz EQ. Even with the 200hz down 1 and the 500hz down 4, the system graphs out hot from about 40hz to 160hz, which is preferred in my opinion to overcome the car environment. Oh, one last thing, I tweaked this with the top down. I'l probably go back and do it again and save the curve for the top up in another of the available 3 memory options. This is one curve Crutchfield's experts recommend: Last edited by antennahead; 01-17-2013 at 11:05 PM.. |
