      04-08-2015, 11:52 PM   #1
koruptor
koruptor's Avatar
31
Drives: 2008 Z4 3.0si Coupe
Low beam issue [HID]
So I recently installed an aftermarket HID kit on my car (Opt7 Bolt). There's an issue I'm having where one of the HIDs don't ignite...initially. It's kind of weird (at least for me because I'm new at electrical), but here is what I've observed:
  • Sometimes the bulbs come on without issue.
  • Sometimes when I start my car I get a bulb out warning (one of the HIDs do not come on). It is never consistent which side this happens on.
  • If I continue driving up to as long as five minutes, the "faulty" HID will come on.
  • Neither HID ever goes out once ignited.
  • I've manipulated/jiggled the HID wires once they are on to see if the HIDs go out. They don't.
Possibly related: When I bought my car, it was in transport mode. It is my understanding that that can occur from a low battery.
Nonetheless, I ran a diagnostic on my car and here are the fault codes. Any help on how to troubleshoot this would be appreciated. Sorry about the formatting below; fault codes are bold.
​Motor Control:
Engine / Motor
ECU OK, no Fault Code
ABS / DSC / Brake:
Dynamische Stabilitaets Kontrolle / DSC
Fault: :Electrical system voltage <9 Volt / Invalid CAS interface / Internal ECU operating error DSC
Code: ​​5DF4
Airbag:
Airbag
Fault: low voltage
Code: 93D0
Fault: Supply voltage Undervoltage in PDC
Code: 9408
Transmission Control:
Instrument cluster:
Instrument cluster / Kombiinstrument
Fault: RDC - K-Bus timeout
Code: 0022
Center-Console/ Schaltzentrum Mitte
Light/Rain Control:
Light / Licht
Heating / AC:
Aircondition / Klimaanlage
Additional heater / Zusatzheizung
Fault: sorry, unknown fault
Code: 00DA
Park distance control:
Sunroof / Roof:
Audio/Navi/Communication:
HiFi
Fault: unknown fault code
Code: ​​6128
Fault: Vehicle speed
Code: 611E
Radio
Fault: Internal CD drive
Code: 0003
Seats:
Seats / Sitze
Systems:
Gateway /ZKE
Fault: Power windows: cable break or jam protection strips de-standardisation/Error EKS Electronic driver's door
Code: 000D
Fault: Power windows: cable break or jam protection strips de-standardisation/Error EKS Electronic passenger door
Code: 000E
Fault: C-bus control unit or instrument cluster base (gateway)
Code: 0030
Fault: Central short-circuit or open circuit on the engine hatch
Code: 003D
Central info display / Zentrales Infodisplay
Fault: Central control timeout
Code: A468
Fault: Communication error
Code: E5C7
Tire pressure control / Reifendruck
Body:
Elektronische Fahrzeug-Immobilisierung
Fault: general reset
Code: 00FF
2008 Z4 3.0si Coupe
      04-09-2015, 06:09 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
You might want to reset the existing codes and get a fresh start.
There's no telling when those codes set and under what circumstances.
      04-09-2015, 08:22 PM   #3
pungo
pungo's Avatar
When you buy a cheap $35 Chinese plug-and-play HID kit, you might not get the most reliable equipment. Maybe adding relays will get them to ignite consistently.
      04-09-2015, 09:52 PM   #4
koruptor
koruptor's Avatar
31
I'll definitely give this a try. Thanks.
2008 Z4 3.0si Coupe
      04-09-2015, 11:56 PM   #5
koruptor
koruptor's Avatar
31
You're absolutely right. I'll try a relay harness to see if that helps.
2008 Z4 3.0si Coupe
      07-16-2015, 02:00 AM   #6
koruptor
koruptor's Avatar
31
So I want to update this thread for those who may have had the same problem or were interested in what happened. Installing a relay most definitely solves the intermittent HID issue. No problem there now.
New problem is that by installing a relay, the passenger HID now has an unused connection. That connection supplies the signal for the bulb check. So I've had a bulb-out warning since installing the relay even though I have no issues with the HID's otherwise.
After troubleshooting with customer service, they were ultimately unable to help resolve the issue other than offer a refund.
So I decided to code out the bulb check for my low beams. It's a band-aid solution, but it'll do for now.
Thanks to those who helped!
2008 Z4 3.0si Coupe
      07-16-2015, 08:39 PM   #7
pungo
pungo's Avatar
Coding to ignore the low beam should be fine since you should easily be able to tell when one or both of your headlights stop working. I'm happy to hear my relay suggestion got them to work constantly for you, the initial HID startup can be a heavy load.
      07-16-2015, 11:15 PM   #8
koruptor
koruptor's Avatar
31
Thanks again, pungo!
2008 Z4 3.0si Coupe
