02-13-2009, 05:46 PM | #1 |
Custom User Title
145
Rep 661
Plz Advise - Evaluating a used Z4M- what to check
Hello Folks,
I have the opportunity to buy a virtually new 2006 Z4M roadster with a mere 1,300 miles on it. It's basically still new. I plan on having a trusted mechanic look at the car. Aside from the obvious signs of accident repair and fire/water damage, what would you recommend I specifically check for ? also, I have concerns about chassis stiffness in a 'vert. I will be adding a strut brace with firewall braces as my first mod. Is there any under- body bracing system for the Z4? Lastly, what other first mods would you recommend as highest ROI without voiding warranty? Big thanks for your insights. Regards Rob Reply With Quote |
02-13-2009, 06:36 PM | #2 | |||
Imola Lover
26
Rep 749
If you do a little bit of searching, this exact topic has been covered countless times
02-13-2009, 07:50 PM | #3 |
Rep 282
Drives: '15 M235 & '95 M3 tracktoy ;
Is that the one at CarMax? It looks like quite a deal, and I'd be after it too if I were in the market for a roadster.
jragan pretty much summed it up. The Z was built from the ground up as a roadster, so its stiffness is on a par with most closed cars, and the coupe is just overkill in that regard (but very useful overkill on the track!) I second the motion about driving school (if you haven't already done so) - most any other mod you can do is just bling if you don't know how to use what you already have (though it's hard to beat the ROI on free for the CDV delete.) BMWCCA schools are quite good, however they are decidedly roadster unfriendly, so you need to go to one of the Porsche club events or one of the commercial schools or organizers. |
02-13-2009, 10:11 PM | #4 |
Imola Lover
26
Rep 749
I concur that the Porsche (PCA) hosted events are some of the best but my experience is that they tend to be lacking for first time drivers. The ones around here, anyway (Maverick PCA) are much better for more skilled drivers. I'd suggest going to a "normal" Bring-Your-Own-Car (BYOC) HPDE hosted by an organization who specializes in HPDEs as they give the best instruction for first-timers.
02-14-2009, 12:27 AM | #5 |
Custom User Title
145
Rep 661
Thanks for the sage advice. Good to hear my concerns about chassis stiffness are unfounded. I fully agree that tightening the nut behind the wheel is the best performance mod. I have indeed been to a handful of BMW CCA LA events at Autoclub speedway in Riverside. Their Car Contol Clinic is a great way to spend a day. I have some years experience driving a S2000. It's no M car, but it does provide some frame of reference.
Thanks again for the advice. regards rob |
02-15-2009, 03:23 PM | #7 | |
3.2 liter grin
Rep 83
Since keeping appearances is out the door, you might as well remove it and keep the part handy. I presume re-installing wouldn't attract attention, all while restoring its 'functionality'. |
02-15-2009, 07:59 PM | #8 |
Imola Lover
26
Rep 749
I've heard (although i don't remember seeing it on mine) that BMW uses a paint marker accross the fitting and the CDV such that if the lines don't line up properly, they know things have been "messed with".
02-15-2009, 09:45 PM | #9 |
3.2 liter grin
Rep 83
It's really too bad that such a simple mod could potentially result in warranty trouble.
I haven't heard of this happening to anyone so far, but there is that. On the flipside, never heard of any problems resulting from a removed / Zeckhausen CDV either. :/ |
