01-23-2017, 10:22 PM | #1 |
Rep 5
Lights....Never noticed 3 months old 2007 Z4
2007 Z4
Headlights.....Their are two headlights on both sides...right? Does the inside one turn on or just around the circle? Also one of my lights is giving out a reddish hue to it....does it mean it's almost out? |
01-23-2017, 11:26 PM | #2 |
Rep 2,546
Inner light is a dummy.
see below Thanks to Ron. R.I.P. |
01-24-2017, 12:59 PM | #3 |
Rep 1,990
With all the posts on this over the years it is amazing to me how folks still come on here asking about it. A simple search would yield the answer(as well as the owners manual).
01-24-2017, 02:34 PM | #4 | |
Rep 4,057
I'm not sure about the reddish hue - knock on wood but thus far I've had no issue with the headlights on my car. I wonder - could there perhaps be something on the headlamp causing this? Maybe a good cleaning, or use of one of the many headlight restoration kits out there (the Turtle Wax one is good in my experience) could help if that is the root cause.
Huz-Z
01-24-2017, 02:59 PM | #5 |
636
Rep 3,124
That's classic Xenon "pink-eye".
That's what they do when they "burn out". Replacement bulbs is a whole 'nuther thread. You'll get sticker shock from reliable sources like a dealer. Beware of Amazon and eBay. Prices are much better, but you have at least a 50% chance of getting a counterfeit copy that's very poorly made and lasts about a month.
01-24-2017, 03:37 PM | #6 | |
Rep 4,365
01-24-2017, 03:46 PM | #7 |
Rep 515
I've been lucky with the replacements I've used. They're the correct spectrum and have lasted 2 years and counting so far. I can see if I can dig up the ones I bought but they were fare cheaper than oem.
01-24-2017, 03:54 PM | #8 | ||
Rep 2,866
01-24-2017, 04:05 PM | #9 | |
Rep 758
Note that when you search for the DS2 bulbs on Amazon you'll get about 3 dozen 3rd party sources. I purchased the bulb pair Amazon sourced directly from Sylvania and had no issues. The 3rd party sources are a coin toss as Stickmon indicated. Link for what I purchased is provided below: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Top Down 365
01-24-2017, 04:50 PM | #10 | |
Rep 2,866
01-24-2017, 05:52 PM | #11 |
Rep 2,546
I recommend purchasing a pair from a reputable source and change both so they are the same color and intensity.
Many people replace them with cheap aftermarket bulbs. Most of these aftermarket bulbs don't have the UV protection to prevent damage to the reflector in the projector. The bulb may last for years, but the reflector damage dramatically effects the intensity of the light output. I've seen the damage on several lights when I had them apart to install dual LED Halos. The damage was only on headlights that had aftermarket bulbs. There's tons more fake the real D2S bulbs. There are plenty of web pages describing how to tell the difference between fake and authentic. Blurry text on the bulb base is a sure sign it's fake. Shop wisely and don't buy Chinese fakes. http://www.osram.co.uk/osram_uk/pres...akes/index.jsp |
01-24-2017, 07:17 PM | #12 |
636
Rep 3,124
I lucked out and bought a pair of Philips 85122CM 5000K bulbs of eBay 4-5 years ago to have as spares for $90 /pair.
I didn't know that fake bulbs was a thing until a couple months later. They looked OK. Passed the laugh test. Philips was spelled with 1 L and not "Phillips". Got pink eye about a month ago and put them in. Compared them very closely with the stock bulbs and they were identical in every fine detail. I want to replenish my spares stock. What do you think the odds are on these: Philips-D2S-5000K-85122CM
01-24-2017, 07:51 PM | #13 | |
Rep 2,866
The problem with these ebay ads is that they can show you a picture of anything, so you'll never know until the item is in your hands for examination. Last edited by XMetal; 01-24-2017 at 07:56 PM.. |
01-24-2017, 08:16 PM | #14 | |
Rep 2,546
01-25-2017, 02:36 PM | #16 |
Rep 4,365
I don't get it? The name brand is 1 L as well, were you expecting 2 since it is most likely a knockoff?
Looks like a pretty legit knockoff if it is one (which we all know it most likely is)
01-25-2017, 03:32 PM | #17 | |
636
Rep 3,124
One of them showed a pic of a bulb that said "Phillips". Maybe made in a basement lab by a guy named Phillip. I agree that eBay can show you a picture of anything and then ship you something completely different.
01-29-2017, 08:34 AM | #18 |
Rep 18,729
I just replaced my xenons two weeks ago. I sourced OSRAM bulbs from Amazon. The package has a counterfeit foil sticker/number you can check on line to check if the bulbs are genuine. The foil sticker breaks upon opening the package.
Now about the install. I'm a very well experienced home mechanic and have been wrenching on BMWs for about 30 years. The bulb replacement on the Z4 headlights is not for a novice IMO. You need to remove the wheels to gain free access to the headlight access doors. The back cover of the headlight is a PIA to deal with if it is the first time you've worked with it. It helps if you have replaced bulbs in various cars beforehand where the bulb is held in place with spring clips. I've run Hella aftermarket globes on the various BMWs and other cars I've owned over the years, so the Z4 setup is quite similar once you get to the actual bulb. The igniter can be tricky also. It has plastic clips that lock it in place, which means you have to be careful with it. My 2 cents.
01-29-2017, 11:14 AM | #19 |
Rep 2,866
I don't quite understand the concept of counterfeit foil sticker/number check. If the counterfeiter can go through all the trouble to copy the bulbs and packagings, why can't they copy those numbers as well as bulb serial numbers and will still checked out as genuine? Amazon is starting to be like ebay - I just can't trust where they are sourcing their product anymore.
01-29-2017, 11:37 AM | #20 | ||
Rep 758
https://www.amazon.com/gp/offer-list...&condition=all
Top Down 365
01-29-2017, 01:10 PM | #21 | |
Rep 2,546
I agree that just because you order on Amazon doesn't mean you won't receive counterfeit products. There are plenty of places on Amazon that will have products shipped directly to you from China. If it's really cheap, it's probably counterfeit. |
01-31-2017, 07:51 PM | #22 |
636
Rep 3,124
If you've done front turn signals a few times, you may find the HIDs easier.
I was able to do it without taking the wheels off, but I've had a lot of practice with the "puzzle box" rear covers. I found that getting the HID bulbs out and in was a lot easier than trying to remove and replace the turn signal stalks.
