10-24-2015, 06:16 PM | #1 |
Rep 779
Diff fluid
Gotta do my diff soon, prob next weekend. I have a bottle open from 2 years ago, if it stays in the bottle, does it degrade or I can still use it ? its redline 75w90 gear oil
-Roranji
10-24-2015, 06:29 PM | #2 |
10655
Rep 4,855
You can still use it
10-25-2015, 05:34 AM | #6 |
Rep 2,782
The main reason for shelf life is moisture getting into the oil.
10-25-2015, 09:22 AM | #7 |
Rep 779
need someone with more chemistry background in this..
if you open a bottle and use x amount, close it, throw it in storage for 2 years, does moisture get in ? i figure plastic bottle is non porous, so nothing get in or out.. but who knows.. water molecules might some how find its way in
-Roranji
10-25-2015, 10:32 AM | #8 |
Rep 758
Oils (motor oil, tranny fluid, diff fluid, etc.) and greases are generally hydrophobic which means they repel water. It's brake fluid which is hygroscopic (attracts and holds water) that you have to worry about storage after breaking the factory container seal.
Top Down 365
10-25-2015, 10:41 AM | #9 | |
Rep 2,782
10-25-2015, 05:26 PM | #11 |
10655
Rep 4,855
As long as the lid has been on, there is no real moisture, only the moisture that was in that air when it closed. And that is generally very little.
Moisture is generally not a real problem, as the diff itself has much more potential to get some moisture inside. The diff has a breather hole, so every time when the diff gets warm/cold it sucks in a bit of fresh air and some moisture. (without a breather hole the diff would be weeping from the gaskets all the time as when it warms up the pressure inside would rise and that is a sure way to get oil leaks) And in that system it is supposed to be 'lifetime oil', so compared to that 2 years in a closed bottle is nothing. Even brake fluid is generally useable for a very long time as long as the lid/cap closes good.
10-25-2015, 07:34 PM | #12 |
Rep 779
so funny thing, i went to grab my redline, it was close to empty.. guess i wont have to worry about it.. have to order a new bottle.. lol
-Roranji
10-26-2015, 05:10 AM | #13 |
Rep 18,696
Convenient topic....
So I may change my diff fluid today on my '08 Z4 Coupe. I plan on using BMW's current SAF-XO 75W-90 diff juice (it's what my '06 E90 325i takes). I'm assuming both diffs (the E90 and Z4) use the same spec oil? Can anyone confirm? Thanks in advance.
10-26-2015, 09:55 AM | #14 |
Rep 779
-Roranji
10-26-2015, 09:57 AM | #15 |
Rep 779
E90 - pretty much any 75w90 that is bmw spec
http://www.pelicanparts.com/BMW/tech...eplacement.htm
-Roranji
10-26-2015, 08:28 PM | #16 |
Rep 1,543
lol....good timing with this. I have a plastic jug (a reused jug...so no foil seal like a new bottle) filled w/ diff fluid from the dealer. I got it a few years ago but never got a chance to do the work (1st it was time, then not having the right stubby hex driver, then time...). It's been sitting in the closet under my stairs all this time. Sounds like it should still be usable.
- Jeff
bosstones' flickr |
10-27-2015, 09:26 PM | #17 | |
Rep 18,696
10-27-2015, 09:44 PM | #18 |
Rep 779
nice, i gave the mailman a break, i didn't prime my bottle, its coming monday after weekend... was hoping to do it during this coming weekend
-Roranji
10-28-2015, 01:28 PM | #19 | |
Rep 2,782
Shelf life can be adversely impacted by improperly storing the fluid (as in storing it in an open container, in an environment with high humidity and large temperature variations). The condensate can react with the additives.
10-30-2015, 12:30 PM | #20 | |
Rep 1,543
- Jeff
bosstones' flickr |
