01-25-2014, 07:38 PM | #1 |
Rep 1,794
06 BMW Z4 3.0si Slow/Rough Start
The starter has been acting up lately. Not sure if it is the cold weather we are experiencing, the battery, or the starter. Usually the crank is very fast, but now there is a hesitation. Any ideas?
01-27-2014, 07:25 AM | #4 |
Rep 204
Agree on the battery. Mine had the original battery and everything was perfect until the cold came in this time, then it was slow, just like yours. Replaced it and all is well again.
Also difficult to say with the video, but that screeching noise after the start may indicate that your starter bendix may need to be regreased. What may be happening is the original grease is gone/damaged and the bendix is slow to retract the gear from the flywheel after the start, so it hangs around a bit longer than necessary, causing the loud screech. Recommend regreasing that when you can or you may need to do a starter replacement before soon. -gc |
02-10-2014, 07:46 PM | #5 |
Rep 1,794
Just to update this thread, it turned out to be the battery. It officially died this morning.
There were some differing opinions on what battery to use. I purchased a group 48/H6 as that is the size that I pulled out of the car. It fit perfectly. |
10-18-2015, 08:54 PM | #6 |
Rep 1,794
Bumping my old thread Weather is getting cooler and the annoying grinding noise is back when starting the car. You can hear it in the video above. I read that something in the starter needs to be lubricated. Is there a DIY for this anywhere?
10-19-2015, 06:51 AM | #7 |
Commander
220
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
I don't know how often you drive your car but if it sits for long periods of time and/or only driven short distances, it may just be the battery going low again. If that's the case I'd recommend a trickle charger.
E86 ///M Coupe - Imola Red/Imola Red
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
10-19-2015, 01:48 PM | #8 |
Rep 406
If you are removing starter to lubricate/repair starter solenoid... I would just replace the starter with a new one instead...
On my '04 3.0i two bolts secure starter. I removed the air ducting/sound generator plenums/ducting from that area to access and provide working space to remove/replace starter from engine compartment... Pretty straight forward after that to get my hands in to access the bolts and starter power wiring.
Sent from my smart phone...
10-22-2015, 08:57 AM | #9 |
Rep 71
related question: sometimes (varies on time of day) my car wont start at all when i insert the key and quickly turn it to ignition, trying it again the second time always cranks the car and turns it on. Should I be turning to key to 'on', waiting, then turning to ignition?
I do hear a faint pumping sound when I turn the key to on in the mornings prior to the ignition. Any idea what that is? |
10-22-2015, 09:05 AM | #10 | |
Rep 1,990
10-22-2015, 08:15 PM | #11 |
Rep 204
My starter started screeching at startup when it was cold so I took it apart today.
Problem: The bell housing collects clutch dust from the clutch/flywheel. This is the same housing that the starter sits in. What happens in the long term is that the clutch dust gets attracted to the starter pinion gear/shaft. It starts to impede the free movement and the gear stays attached to the flywheel for too long. Result is a screech at startup. In this case, I retract my earlier statement about regreasing - I highly recommend against regreasing this shaft/gear since it will just cause the clutch dust to cake on even stronger/faster. Instead, I recommend stripping the starter and solenoid housing and cleaning everything up. Here are some pics to help you see what it looks like inside |
