      06-18-2015, 06:33 PM   #1
unluky
unluky's Avatar
7528
Make sure I am right on Sport Package....
So I have a 2004 3.0 with sport package - which means I need to order the M/Sport versions when I order springs and shocks - correct???
No??
      06-20-2015, 08:02 PM   #2
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
Correct. Part of the sport package is the M Sport suspension. Note that this is not the same as the suspension on the Z4M.
Top Down 365
      06-23-2015, 04:02 PM   #3
Twixboy
Drives: '04 Z4 3.0i 6spd
If you need to replace your springs and shocks, going with OEM parts is going to cost you more than a decent set of aftermarket coilovers which will also improve handling. Just something to consider.
      06-25-2015, 05:28 PM   #4
unluky
unluky's Avatar
7528
I actually do not want to go OEM - I was planning to go Eibach since I had them on my 300Z and loved them, but I see they are even drop all the way around and I like that the H&R has more drop in the front. If I am reading right, they might be a little harsher though.
I don't want coil overs, but if I buy aftermarket springs and shocks - would they be the same as a regular 3.0 Z4 then? I kind of was looking at the H&R Blistein combo package from turners, but their fit checker does not have a selection for sport package.
      06-25-2015, 08:12 PM   #5
Steeler
Steeler's Avatar
2429
I did a drop on my daughters 2.5
Used ST springs and konis. Gave a 1" drop in the front and 5/8" drop in the back.
