      12-16-2011, 07:12 PM   #1
bigbacon
Drives: 03 Z4
oil change question
so...
I've read some stuff on this but I am still sort of un-sure about this.
I have a jack and jack stands.
I can jack up the front by jacking up there rear and get the stand under the front. How far off the ground do you guys normally get the car?
It is high enough for me to shuffle under there on my back but not much else.
Does it help to jack up both side of the front?
      12-16-2011, 07:43 PM   #2
RADRACR
RADRACR's Avatar
For oil, I recommend ramps. Then you can fit the jack under the front (using the center lift point) if you need to go higher. You don't even need to get your body under the car if your arms are long enough. I can get at the drain plug just by reaching under from the side of the car.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      12-16-2011, 07:45 PM   #3
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
You a Basketball Player?
2006 Z4MC - #LL93158
      12-16-2011, 07:57 PM   #4
RADRACR
RADRACR's Avatar
At 6'5", I lack offensive skill but have solid D + rebounding
      12-16-2011, 08:27 PM   #5
Barryb97
Drives: 2006 M coupe
I usually jack up both sides just so it is level side to side but there is really no need.
      12-16-2011, 09:10 PM   #6
tekmoe
tekmoe's Avatar
55
Drives: ///M
Jack up the front drivers side, place a jack stand underneath, crawl under and undo the oil drain plug. Then lower the car, let it drain, jack it back up, put the oil drain plug back in, and lower the car.
      12-17-2011, 01:32 PM   #7
bigbacon
Drives: 03 Z4
where do I put the stand if the jack point is used by the jack?
      12-17-2011, 01:50 PM   #8
jmillet
jmillet's Avatar
64
Your non-M Z4 doesn't have a front center jack point. Ramps are probably your best solution. Jack up the front using the front side jack pad and slide the ramp under the front tire. Lower the car onto the ramp and repeat process on the other side.
I use the 8000 Rhino Ramp http://www.rhinoramps.com/product.html
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      12-17-2011, 06:17 PM   #9
claritycheck
Rolling Republic
claritycheck's Avatar
Drives: M Coupe
I have an oil pump that siphons from the top of the engine into a container, because I hate jacking up and what not. For $80 and re-usable, it definitely makes life easier.
      12-17-2011, 07:48 PM   #10
dreamingat30fps
Drives: Miata, Cayenne, Model 3, F350
Which pump do you use?
      12-18-2011, 03:47 PM   #11
bigbacon
Drives: 03 Z4
Is the thing bavauto sells?
      12-18-2011, 07:20 PM   #12
claritycheck
Rolling Republic
Drives: M Coupe
Correct! On my phone at the moment. If someone has a link to the pump could you please direct these fellow Z's!
      03-23-2012, 03:09 PM   #13
bigbacon
Drives: 03 Z4
is there a torque setting for the oil cap?
      03-23-2012, 03:16 PM   #14
gcochard
Drives: 2011.5 E90 M3
2011 BMW M3  [0.00]
According to http://www.m3forum.net/m3forum/showthread.php?t=34365 and http://billswebspace.com/Z4MS54OilChange.htm
18 ft-lbs
      03-23-2012, 05:41 PM   #15
bigbacon
Drives: 03 Z4
i am a tard...super easy though I wonder if my vac thing is broken. it took like 10-15 minutes to get all the oil out and the pump handle would raise on its own after pumping.
worked though, so easy.....
