      08-24-2017, 12:27 PM   #1
Eson
Eson's Avatar
77
Drives: BMW
S54 Catastrophic Failure
Hey fellas,
After four previous S54 powered cars, my luck ran out with what I thought would be my most robust one yet -
2007 Z4M Coupe. Street driven, 42k miles, 3-5k oil change/15k valve adjustment intervals documented since new. Most recent oil change and valve adjustment was 1,400 miles prior to this mishap...
After previously driving spiritedly (though no overrev, money-shift, etc...), my motor began knocking in 4th gear at 2k RPM. My initial thought was a rod bearing very prematurely spun as it was a consistent "slap" and the typical go-to S54 issue, but that surprisingly was not the case ---
After dropping the front subframe, removing the oil pan, inspecting the rod bearings, main bearings, and crank, I pulled the valve cover and plugs where I took a borescope down cylinder #2 and found that the top of the piston was polished clean from hitting the cylinder head. I have not yet been able to determine why, though I did NOT spin a bearing. I'm going back under to see if there is play in the rod, if a wrist pin bushing broke, etc. Regardless, the piston is slapping.
This leaves me with essentially four options -
1.) Rebuild at my trusted local shop and have the machine work done at a nearby reputable machinist. This would consist of OEM, CP pistons, Carillo rods, and Schrick cams, etc... $14k
2.) Source a used S54 for $4-5k, spend $$$ on Beisan VANOS, bearings, cams, and airbox for a total of roughly $10k.. all while hoping lightning doesn't strike twice in the same place.
3.) Buy a BMW crate motor for $15k.
4.) Have Lang Racing build me a mildly modified motor (CP pistons, carillo rods, Beisan VANOS, 288/280 cams, DLC rockers, widened rod journals, etc, etc).
5.) Dinan. $$$$$$, but Dinan.
Keep in mind this is a low mileage, otherwise mint Z4M Coupe that I now plan to keep for at minimum a few years
Are there any options I'm overlooking? Thoughts?
Redacre369.00
StickMon636.00
3GFX722.50
      08-24-2017, 01:25 PM   #2
deemo319
deemo319's Avatar
Drives: BMW
      08-24-2017, 01:33 PM   #3
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
      08-24-2017, 01:46 PM   #4
W///
W///'s Avatar
7496
Drives: F82GTS, E36/E92M3, Z4M
Ouch, all those numbers hurt. Didn't you just get this M Coupe not too long ago (I also follow m3f).
Sorry to hear about the troubles. I'm at 92k miles so it's time high time to do some preventative maintenance.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      08-24-2017, 01:59 PM   #5
GuidoK
#buildnotbought
GuidoK's Avatar
10871
Drives: Z4 3.0i ESS TS2+
I'm very curious what finally caused it.
As for the options, I certainly wouldnt rebuild this motor/use this block unless you've 100% identified the cause (and all potential damage of it) of the failure and you're sure you can correct it.
NickyC17499.00
      08-24-2017, 02:18 PM   #6
RABAUKE
Drives: Porsche 993, 2014 MB GLK
OUCH! #4
      08-24-2017, 05:01 PM   #7
NickyC
NickyC's Avatar
17499
Wow, so sorry to hear this and of course the nightmare scenario for any Z4M owner. My personal opinion is to go with #4 if you have the time to spare/extra car to use etc. I'd consider #3 if it came with a warranty from BMW, which I think it does (2 years right?).
I'm very curious to hear what caused this, as it doesn't sound like any of the known traditional issues the S54 can have?
Best of luck to you, and believe me my heart goes out to you on this.
      08-24-2017, 05:36 PM   #8
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
Crap! Sorry to hear all this!
Definitely interested to see what the root cause is on this one.....
Top Down 365
      08-24-2017, 08:02 PM   #9
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
Yikes. Sorry man.
I'd probably go with #2. Odds of this happening again are pretty low I imagine. Might be able to save some of the upgrades (beisan, etc) from your dearly departed if you already have them.
      08-25-2017, 04:08 PM   #10
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
I'd probably buy a used low mileage S54 and just drop it in. You could do that 3 times before you reach the cost of replacement. Then modify the used motor. Perhaps a supercharger if you want more power.
      08-25-2017, 08:00 PM   #11
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
#2 without the cams and air box would be your most economical solution for now.
I'm not a big believer in the more frequent oil changes = longer engine life. It all depends on what ultimately fails. In your case it sounds at this point not to be lubrication related.
Likely a fluke. Pick up the dice and throw them again...
      08-26-2017, 12:28 PM   #12
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
I'd probably take that as a great time to make a stroker motor. Vac has a nice kit.
      08-31-2017, 03:40 PM   #13
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
#4 or......LS3. With a new crate engine, trans, tune, and other stuff to make it work you are probably near the $14-$15k mark
(sacrilegious I know, but tempting)
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      08-31-2017, 07:49 PM   #14
m5m3mc
Drives: M-B C63
A crate motor is really only $15k? That's a bargain price IMO.
      09-08-2017, 11:09 AM   #15
Eson
Eson's Avatar
77
Drives: BMW
Thank you all for the input - I appreciate it!
I've decided to have Dinan (SD Autotech) build me a motor.
11.7:1 CP, 3.3L, forged internals, Carillo rods, 288/280 Schrick cams, DLC rockers, etc, etc..
Will update!
      09-08-2017, 12:34 PM   #16
NickyC
NickyC's Avatar
17499
Will update!
Wow, please keep us posted!!
Did you ever find out what caused the failure?
      09-08-2017, 01:09 PM   #17
Eson
Eson's Avatar
77
Drives: BMW
No, not yet. The motor should be out of the car this afternoon, so I'm anticipating tear down to start Monday.
NickyC17499.00
      09-19-2017, 02:28 PM   #18
GQM
The Slip Angle
GQM's Avatar
31
Drives: 2007 BMW Z4 ///M Coupe
Any updates on this? I am curious to know the root of the failure as well.
2007 BMW Z4 ///M Coupe | 1993 Mazda RX-7 Turbocharged 417 whp | 1999 Mazda Miata All Motor 185 whp | 1991 Mazda Miata N/A 13b PPort | 2003 Honda S2000 All Motor 238 whp | 2006 Mazda RX-8 | 1998 Lexus LX470 | www.instagram.com/garagequinnmotors
      09-19-2017, 04:45 PM   #19
Eson
Eson's Avatar
77
Drives: BMW
Oddly enough, there was a shard of stainless steel found in the combustion chamber that was lodged between the #2 piston and the cylinder head. After hours of disassembly and digging, Steve Dinan actually found the culprit to be a tiny piece of welding broken off of my newly purchased (<100 miles) ACTIVE AUTOWERKE headers - a terrible construction flaw. I questioned how the piece essentially swam back upstream into the motor, but Dinan assured me it's surprisingly plausible - someone whose opinion I value beyond measure. He/his shop verified no other failures (not intake, valvetrain, head, block, etc) anywhere else.
As time permits, I'll go into more depth with a writeup.
      09-19-2017, 05:16 PM   #20
GuidoK
#buildnotbought
GuidoK's Avatar
10871
So then how made that slap the piston agains the cilinderhead?
      09-19-2017, 07:24 PM   #21
NickyC
NickyC's Avatar
17499
wtf....................
      09-19-2017, 07:51 PM   #22
StickMon
StickMon's Avatar
Drives: 2006 MR
It didn't. It was hammering the piece of steel between the piston and head.
I had a similar fate befall my '73 Sports Bug when a piece of the Cal Custom air cleaner fell down the intake.
