      07-23-2013, 04:28 PM   #155
Tonybest
Enrollment Officer
Tonybest's Avatar
Drives: 997.2 Porsche C4S
Originally Posted by sabbanick View Post
Thats scary.
Dsc on or off?
Always off. Since this year, I have also taken it off in the rain
Very hot day, no rain... might it be that trail-braking could be causing this?
      07-23-2013, 07:36 PM   #156
Krypptic
Drives: E92M, GT3
Don't think trail braking would cause uneven wear on pads. Your pad probably over heated and the compound crumbled off the shoes.
Did you get any pad deposits on that rotor?
      07-23-2013, 07:46 PM   #157
sabbanick
Drives: 08 SBM M coupe
I'd check the caliper pistons and seals then for piece of mind. Something's going on and if it was me I'd rule everything else out before I blamed it on the pad.
      09-30-2013, 09:47 AM   #158
Tonybest
Enrollment Officer
Tonybest's Avatar
Last event of the season. Friday the 27th of September at Calabogie. CMP days. Advanced group. best lap time was 2.27.8 with NT01 that are now corded (all 4).
And at the start of the day one of my Wheel studs broke off Inside Wheel...
Now my off season should be quite busy for my M.
Planned :
new Wheel studs
new NT01
half cage
racing seats
KW Clubsport (?)
front swaybar H&R 30mm ajustable (?)
rear swaybar Ground Control ajustable (?)
      11-06-2013, 10:51 AM   #159
Tonybest
Enrollment Officer
Tonybest's Avatar
My car is now over 80,000 kms.
It's in the shop at this moment having the half cage done, and the seats and harnesses installed.
Then it will be properly washed, claybar, waxed etc to be stored over our harsh winter.
      11-16-2013, 09:06 PM   #160
Tonybest
Enrollment Officer
Tonybest's Avatar
Here she is. Seats, Harnesses and proper roll bar fitted.
