Go Back   ZPOST > BMW Z4 Roadster and Coupe > Regional Forums > Canada
      05-27-2019, 07:32 AM   #1
accent
Drives: '03 2.5 Z4
Clutch
2003 2.5, just passed 100,000 miles. The clutch is slipping now, so I have to get it replaced. Does anyone have a recommendation for an indy near Hamilton, and/or a parts source?
Thanks in advance
      05-27-2019, 01:58 PM   #2
garz747
Drives: 07 Z4MC 01 330i 18 X3 M40i
factoryautoparts.ca has an ad on kijji ontario under E46 clutch . Brand is LUK and part price is listed at $415
      05-30-2019, 12:48 PM   #3
accent
Drives: '03 2.5 Z4
thanks for the lead. I had two quotes from indies, both at $1000 for labour and clutch kit. Problem is that there is a dual max(?) flywheel that supposedly usually needs replacing and it lists at $750 for LUK brand
I found the same one on rockauto for $366, so I booked one of the indy guys to do the work and I supply the flywheel if needed, Means the whole job will be about $1500
