12-01-2015, 01:09 PM | #1 |
Rep 279
Another Third Brake Light Issue
So after finally spending the dough on a new third brake light, 200 dollars later (import and taxes of canada) I connected to find that even the new one doesn't function. I've looked for info elsewhere but no conclusions on this one. I cleaned the connections, checked for water damage or damage of any kind and I am out of ideas. Any help is appreciated, thanks.
12-04-2015, 05:00 PM | #3 |
Rep 279
12-05-2015, 12:14 PM | #4 |
Rep 847
Check out the wires crossing from the body into the trunk lid. Over time opening/closing the trunk damages the wires. IIRC the loom passes into the trunk lid at the bottom right corner. Here's a thread with pictures (E39 but the same concept): http://www.bimmerfest.com/forums/sho....php?p=5496188
12-08-2015, 02:28 PM | #5 | |
Rep 279
12-08-2015, 02:53 PM | #6 |
Rep 904
I don't recall seeing 2 plugs when I replaced mine. Do you have a picture?
12-08-2015, 03:04 PM | #7 |
Rep 1,061
There are two plugs on my 06 that are identical. 3rd brake light only works when connected to the right one.
12-08-2015, 03:21 PM | #8 |
Seasoned Novice
Rep 54
Mine third lamp feed wire was connected to another plug and when I connected to the light it started working. As far as I could tell it had never been connected to third lamp. I think other plug provides resistance so system doesn't detect light out malfunction.
.HanK.D.KranK. <<<<<<<<<< |
12-08-2015, 04:24 PM | #9 | |
636
Rep 3,124
Can't substantiate that it doesn't work if plugged into the wrong one, but I wouldn't doubt it.
12-11-2015, 02:39 PM | #10 |
Rep 279
I'll post some pics up as soon as I can, I've tried both and neither seem to work. I really hope it's not a tricky wiring issue as I already paid over $200 for this little light bar, arg!
01-15-2016, 03:51 PM | #12 |
Rep 279
Welp, no power going to the cables so I have to imagine the wiring is to blame here. I'll be leaving this for the spring when it's not finger numbing cold but I sure hope I didn't buy a new third brake light for nothing.
01-15-2016, 04:28 PM | #13 |
636
Rep 3,124
The new one won't go to waste.
Yours may eventually crack, or you can sell it at a minor loss in the classifieds.
01-16-2016, 04:01 PM | #14 | ||
Rep 528
Drives: E86 Z4MC; E92 M3
Here's hoping that you the new light will work, but if not I could help mitigate your repair expenses. |
03-18-2016, 04:06 PM | #15 |
Rep 279
Well just wanted to finally update this. Turns out the wiring for the third brake light was broken in a few places. My mechanic managed to stitch em' up and the original brake light works just fine. I think i'll be keeping the new one just in case though. Thanks everyone!
03-19-2016, 12:00 AM | #16 |
636
Rep 3,124
Update here, too.
Been quite a while since I put Nyloc nuts on and tightened them roughly 1/2 way down the threaded portion. No new cracks.
03-19-2016, 03:59 PM | #17 | |
Rep 279
I have not yet had cracking, this is why I ask. |
03-20-2016, 11:28 PM | #18 |
636
Rep 3,124
Some do, some don't.
Maybe it's the California Sun, maybe it's vibration from my RE cans. Maybe it's because my trunk lid's not straight. I'm convinced my car had rear end damage from the P.O. that didn't make it to CarFax. Anyhoo, my original light completely shattered. I put a new one in and within a week there were cracks along the top edge. Went to Lowes and got some Nylocs and only put them on 1/2 way. Cracking stopped. By design, you shouldn't be able to over tighten them. There's a positive stop when you hit the shoulder of the studs, and the springs set the force on the light housing.
03-21-2016, 09:01 AM | #19 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Salty
03-21-2016, 07:37 PM | #20 |
636
Rep 3,124
The left side of my trunk lid doesn't line up with the fender. Like the lid is bent.
Maybe somebody tried to slam it with too much junk in the trunk, or maybe it was hit and they didn't get it back quite straight. On the right side around the edge of the tail light and that little plastic trim piece the lip on the fender is folded under. It's supposed to go over the edge of the plastic trim piece, but isn't close. The hole for the brake light looks OK, but it would only have to be off by a couple of mm to put all the stress on the center few inches of the light.
03-21-2016, 07:54 PM | #21 | |
Rep 2,704
I adjusted the hinges by loosening the bolts and realigning the lid. Drove me nuts looking in the rear view and seeing the lid misaligned. Wonder if all were made that way by BMW
03-22-2016, 03:43 PM | #22 | |
Rep 279
