      12-04-2011, 08:56 PM   #1
z4xtreme
Drives: z4 roadster 3.0i
Angry Rear Bumper Surprise
Hey guys,
New z4 owner, and getting ready to take care of my z4. As I was getting ready to swap rear bumper for new one, started doing some research and need some help to replace a few broken parts
So I'm here to be pick your brains:
- On the left side, (red circled area) what is that set of cables called??? Part number or name??
- To the right (square red area) besides the side marker and license plate, what should I expect to see?
What is that multipoint cable on the left for?? should I have the same on the right?? what should I have on the right?
Will post pics when I get this replaced and back on the road, cheers
      12-04-2011, 09:17 PM   #2
Barryb97
Drives: 2006 M coupe
I believe the wires on the left are the radio antenna. The wires on the right should be for the rear marker light.
CDV delete, clutch stop, BMW pedals, Strongstrut bar, CF rad & coil cover, M3 reps, roundel under hood, Intravee II, air bag sticker delete, first aid storage, painted reflectors, headlight washer disable, Skyer CF front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler and diffuser, oil pressure and water temp guages.
      12-05-2011, 07:15 AM   #3
Shipkiller
Shipkiller's Avatar
Drives: Me
Barry97 is correct. The semi-rigid 'net like' looking harness on the left is the FM antenna. The right wire is for the right marker light. There should (better be) be a similar one on the left side.
      12-05-2011, 10:24 PM   #4
Ron Stygar
Drives: 2006 Z4 M Coupe
FM had said
Page 10 start:
http://www.unofficialbmw.com/images/...unications.pdf
      12-05-2011, 10:37 PM   #5
z4xtreme
Great!!
Thanks guys, now I can start the job without being afraid of any surprises or complications!!!
You rock!!!
