      04-03-2016, 04:20 PM   #1
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Wheels option for track 18x9.5 et 25
Hey guys,
Any company that makes wheel this size so that way I dont need to use spacers?
Funny how a 25 doesnt rub, but a 22 rubs =(
      04-05-2016, 03:31 PM   #2
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Why not run E35 and a spacer? Plenty of options then
      04-05-2016, 03:56 PM   #3
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
because I don't like to use spacers on my track cars
I have seen friends who studs broke in half before cuz of spacer
Instagram: ariusen26
Youtube: Track vids
      04-05-2016, 04:15 PM   #4
MeisterS
Rennfahrer
MeisterS's Avatar
47
Drives: E90 325xi E36 M3 & E92 M3
Tried Forgestar yet?
Current- Jerez Black E92 M3 | Arctic Silver E36 M3/4/5 | Monaco Blue E90 325xi
Past- AW Z4-M roadster| JB Z4-3.0si | '98 Accord V6 coupe
      04-05-2016, 04:19 PM   #5
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Originally Posted by AriuSen View Post
Hey guys,
I've been trying to get a grasp on wheel numbers and thought I had it figured out. Wouldn't an offset of 22 give you 3mm more clearance on the inside than an ET 25? If not, I'm really confused.
Salty
      04-05-2016, 04:27 PM   #6
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
To each their own. I know of at least two people running spacers on Z4M dedicated track cars without issue.
      04-05-2016, 04:27 PM   #7
The HACK
The HACK's Avatar
1821
Which wheel is rubbing and where? If the difference in 3mm is causing rub, you have 2 options:
1. Leave it be, it'll self correct or
2. Moar camber.
      04-05-2016, 04:33 PM   #8
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Hey guys,
Salty
yes... 22 will give you more clearance on inside... my problem is the outside.
Youtube: Track vids
      04-05-2016, 04:36 PM   #9
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
2. Moar camber.
it's rubbing all 4.
i already have - 3.5 on front and - 2.5 rear
problem is that doesn't rub on top part of fenders... it runs on the sides when I hit bumps, and my car wasn't even that low
I can't just live with it, cuz 1 tire got destroyed and I threw away.
offset 25 is perfect for me.... i found one.... advan rs-d... they r super light too... I think I'm getting that one.
Youtube: Track vids
      04-07-2016, 08:50 AM   #10
pal
pal's Avatar
433
Drives: Z4 M Coupe
Forgestar is a great option to custom order a size and offset for a reasonable price. It does take them 8-10 weeks to build and ship though. I recently ordered a set of Forgestar CF5 18x9.5et52 in gloss black for the TT RS so I can run 275/35 tires without rubbing or spacers.
      04-07-2016, 11:03 AM   #11
The HACK
The HACK's Avatar
1821
18" x 9.5" et 25 is a common fitment on E60 5 series with staggered sports package. Unfortunately that's not a common car people track. Also you'll need a thin by centric ring adapter.
Some of the bigger wheel companies that also make wheels for 5 series may have them in light weight track able rims, like BBS.
      04-07-2016, 02:36 PM   #12
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
I ended up finding a volk TE from a friend used 18x9.5 et28. 3mm is acceptable compared to the thick 10mm one.
thanks!
      04-07-2016, 03:17 PM   #13
The HACK
The HACK's Avatar
1821
Also Enkei NT03+M has a 18x9.5 et 25 that has the 5x120 bolt pattern too. Along the same lines I believe there are a few Rays options that would be in that et25-30 range.
      04-07-2016, 03:18 PM   #14
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
really???... hmm I tried finding nt03, but they were all et 22...will double check
edit.. you sure you didn't see 18x10?i cant find et 25 on 9.5
Youtube: Track vids
      04-08-2016, 03:05 PM   #15
The HACK
The HACK's Avatar
1821
Um...Yeah, it's the 10" wide rims I saw with et25. Sorry.
Too bad that Apex don't make the Mustang offsets readily available to us. They make a 18" x 9.5" with et25 but with 5x114.5mm bolt pattern. IMO that's the PERFECT offset for this car.
