07-22-2014, 01:37 PM | #1 |
E86MPilot
23
Rep 265
Authentic BBS RGR 19 inch Diamond Black wheels for Z4M
Sold For sale is an Authentic BBS RGR 19 inch Diamond Black wheels, come with Special Edition BBS Red/Gold caps or black/silver, Michelin Pilot Sport A/S tires are mounted on with only 7K miles, and it has lots of threads left 75-80%. Mostly driven on Highway between PA and NJ. It's one of the lightest 19 inch wheels available from BBS. I had these wheels on my Z4M Coupe on factory alignment""" Looks was awesome. It had a little bit of rubbing on the rear tire during high speed hump, but a small negative camber or roll should solve the issue. Pictures attached http://www.cars.com/vehicledetail/de...4735/overview/ http://www.zpost.com/forums/showthread.php?t=629084 http://share.shutterfly.com/share/re...Bbs2jFoxZs2rww Total asking price $2500. Here are the spec from Tire racks: Front Fitment 19x8.5 $1,070 (each) New Offset: 32mm Backspacing: 6.06" Bolt Pattern: 5-120 Rec. Tire Size:245/35-19 Weight: 20.3lbs. Rear Fitment(my offset is 20mm) 19x10 $1,155 (each) New Offset: 20mm Backspacing: 6.49" Bolt Pattern: 5-120 Rec. Tire Size:275/30-19 Weight: 22.0lbs.
E46M, E60/545I, E36/Z3M, E92M DTC, E93M 6spd, E86M(x2), F10 550XI (S2)(Current)
Tags |
bbs rgr 19 inch diamond black |
