      03-15-2013, 07:08 AM   #1
elwesso
elwesso's Avatar
25
Drives: Z4 M Coupe
Z4 M: DIY Drive Belts and Tensioners
I recently had to replace an idler pulley on my Z4 M, and learned a couple things along the way.. Most of the information is here:
http://www.bimmerfest.com/forums/sho...d.php?t=462797
One important thing to note is based on my experience, and extensive research, is that the S54 engine tensioner pulley on the alternator/water pump seemed to jump back and forth between a T50 torx and 8mm socket head screw. This is what you need to loosen the tensioner off the belt. Really annoying if everything you read is 8mm socket head and you need a T50 torx, so I'd recommend having both.
ECS tuning has most of the belt drive components.
- Wes
2007 BMW M Coupe
2016 VW GTI
      03-17-2013, 12:24 PM   #2
mhughett
Drives: 2007 Z4 M Coupe
Early last year I had an pulley that was squealing like a pig at idle so I replace my belts, pulleys and tensioners. Removing the belts is a piece of cake from down below. There isn't enough room from above without removing the fan shroud. For those of you that have Harbor Freight tools in your area, they have a special tool for removing expanding rivets that is really nice. They call them push pins. Removing these is easy with this tool.
http://www.harborfreight.com/push-pin-pliers-67400.html
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2.
