11-19-2018, 04:22 AM | #1 |
Tassadar
Rep 11
Wider "Stock" Rims?
This may sound like a dumb question: Does BMW make the same stock rims but 1" wider?
Bought car used and found the tires were way wider than stock: Stock F: 225/45 Stock R: 255/40 Mine F: 245/40 Mine R: 285/35 The rims look exactly like stock rims from the side. What was odd was that the tires actually they sit on the rims perfectly. With 30mm increased width, the tires would budge on the sides of stock rims. When I finally got around to taking the wheels off and measuring, to my amazement, the rims were 1" wider than stock with the same offsets: Stock F: 8" ET42 Stock R: 9" ET30 Mine F: 9" ET42 Mine R: 10" ET30 I didn't think they made Rims that looks the exact same as the stock rims but were 1" wider with the same offsets. WTF??? Did BMW actually make wider stock wheels or are these some aftermarket knockoffs? This is what they look like: |
11-19-2018, 04:44 AM | #2 |
11118
Rep 4,930
Afaik bmw made style 224 only in 1 widht set (8"front, 9"rear)
Are you SURE you measured the correct way? within the bead seats? (that means taking off the tyres) If I look at your picture the tyres look pretty puffy on there but its not the best picture to judge. More detailed pics, taken in the line of the rims, (especially from the front wheels) would be better in this case so people can actually see and compare.
11-19-2018, 09:47 PM | #3 | |
Tassadar
Rep 11
Man,... I spent so much time trying to find who sells the same rims but 1" wider.... turns out I just measured it wrong Thanks for the help.... Now i'm worried maybe the 285's on the 9" is a safety concern. |
11-20-2018, 02:43 AM | #4 |
Rep 882
A 285 tire may be different between manufacturers, it depends on the tire side wall design and how they measure.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
11-29-2018, 11:10 PM | #5 |
1821
Rep 5,337
What’s stamped on the back of the wheels?
12-23-2018, 08:56 PM | #6 | |
Rep 758
Top Down 365
12-25-2018, 03:00 AM | #7 | |
Rep 882
But as I said before, "A 285 tire may be different between manufacturers, it depends on the tire side wall design and how they measure".
