      08-01-2014, 07:16 PM   #23
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
The base plates for the front arms was a PITA !!!
      08-02-2014, 05:38 AM   #24
jetbill
jetbill's Avatar
198
Drives: G80 M3
Sub'd ...makes me want to buy a E87.
Nice coilover setup.
      08-02-2014, 12:48 PM   #25
AmmarYasirA
Ammar
AmmarYasirA's Avatar
Drives: a lot
Waiiiiiittt... How are the seats supposed to fit? Isn't that bar really in the way? Or is that just the way the pic was taken?
E85 ///M Roadster -SapphireBlack/Imola - Garage Queen
2018 F150 Platinum - Black/Black - Leveled on 34's - DD
      08-02-2014, 01:14 PM   #26
gmd2003
gmd2003's Avatar
352
The Recaro's fit in great and I'm 6-1. You have to remember there is a gap because all the trim is out of the car right now .
      08-03-2014, 09:12 AM   #27
Beedub
i think they've done an incredible job tbh..... can't wait to see it all wrapped up and interior back in!...
i think i would have made a DIP to mirror the shape in between the stock roll hoops if you get me, then had a mid cross bar to allow easy point to mount an in case go pro Etc.
      08-03-2014, 09:46 AM   #28
gmd2003
gmd2003's Avatar
352
The cross bar position does not obstruct my visibility at all and was chosen to meet SCCA racing regulations for strength . I will still use my old go pro 3m mount position on the center trim once it's reinstalled . It's a perfect angle no use changing .
      08-04-2014, 03:17 PM   #29
3002 tii
3002 tii's Avatar
2288
Looking good, I made the hard decision to go welded roll bar, no going back but no regrets neither. I feel 10x safer on track running roll bar + 6 point + HANS. GL with build!
Follow for latest mods
      08-04-2014, 08:29 PM   #30
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
does this mean the soft top is permanently removed?
      08-05-2014, 01:49 AM   #31
Beedub
gone for ever!
      08-07-2014, 01:37 AM   #32
Beedub
i need a my weekly fix please.
      08-09-2014, 11:01 AM   #33
gmd2003
gmd2003's Avatar
352
They are working on the strut tower reinforcements now , very complex , essentially a steel plate shell is being added to the entire towers and tied in to both the cage and a cross brace . No way in hell the rear coilover will break through . Pics soon .
      08-15-2014, 10:50 AM   #34
gmd2003
gmd2003's Avatar
352
Those rear coilovers are not going anywhere lol . Pics are with the KW's still in place but MCS setup will be in the same place . Just the tabs for the rear strut bar to go then off to powder coat !!
      08-15-2014, 11:23 AM   #35
sunealio
Drives: Z4 M Roadster
I've waited for someone to do this to a roadster forever. You give hope to all us soft top tracktards!
Do you think there's any safe way to fab and secure a harness bar between seat backs, while keeping the folding top in place? Without a roll hoop/half-cage.
      08-15-2014, 11:26 AM   #36
gmd2003
gmd2003's Avatar
352
A harness without a half cage is a bad idea safety wise . Got to go all in .
      08-15-2014, 01:55 PM   #37
Beedub
these people doing this work are incredible . nothing less.
      08-26-2014, 12:56 PM   #38
gmd2003
gmd2003's Avatar
352
Everything is off to be powder coated , and in the meantime I am installing the MCS 2way suspension. She hopefully will be good to go for my Sept 5th track day at Roebling.
G
      08-26-2014, 01:05 PM   #39
sabbanick
Drives: 08 SBM M coupe
good stuff, what spring rates did you decide to go with out of curiosity?
your going to love your new setup, excited for you!
      08-26-2014, 01:28 PM   #40
gmd2003
gmd2003's Avatar
352
I went with 700 hyperco front and 450 hyperco for the rear coilover per James Clay's recs . So the equivalent of 700f/900 rear on the OEM suspension geometry .
      08-26-2014, 05:35 PM   #41
sabbanick
Nice. This is what I will covert to as well when I swap to a coilover setup in rear...I have 700/850 springs currently. I went from stock suspension to MCS and car really feels transformed - my rear end was very very twitchy is stock form when driving on limit. I have been doing lots of a/x lately and little track unfortunately...but at local track NJMP I dropped almost 4 seconds after two events. Still was driving expecting car like I it knew it in stock form and kept saying..good god I can carry more speed. All this new found grip!!
      08-29-2014, 09:20 AM   #42
gmd2003
gmd2003's Avatar
352
What damper settings and PSI are you running now ?
Thanks
G
      08-29-2014, 10:38 AM   #43
sabbanick
kept psi as they came...sadly i haven't picked up a check valve or recharge tank for Nitrogen.
i run my car (a/x) at a really bad lot so i have found dialing out a lot of rebound is my best friend or else my car just skips over all the bumps and cracks. I need to get some more track time but I've just been running BW's reference settings for time being as i am still learning all my new found grip. Sadly i don't foresee me hitting up the track this season. Will be a project for 2015.
      08-30-2014, 07:27 AM   #44
gmd2003
gmd2003's Avatar
352
Alright so the MCS suspension is in and the cage is back from the powder coater ! Should have her back completely done on Tuesday or Wed !
