08-19-2010, 04:13 PM | #1 |
Rep 316
Inaccurate Speedometer?
hey guys,
i've been noticing my speedometer seems inaccurate. The MPH seems "sluggish" on both acceleration and decelerating. I also noticed my RPMS is not at 0 when the car is started and idle in Park. I did recently removed my gauge cluster to clean the lenses and am wondering if i possibly "moved" the needle? note: when the car is off- both the meters are at 0 thanks shawn |
08-19-2010, 05:36 PM | #4 |
Rep 1,143
Your car needs to idle at a certain RPM > 0 -- otherwise your engine would stall.
As far as the sluggish MPH response, it looks like you have an automatic transmission, which operates through a torque converter vs the the direct gear-to-gear engagement you'd find in a manual. It's a fluid coupling vs. a mechanical one, which is why your car can be in gear (drive) while you're stepping on the brakes, and still not go anywhere. For that same reason, there will be a slight lag between the RPMs and your speed. |
