08-12-2010, 10:54 AM | #23 |
Rep 1,855
Getting into 2 is less jerky, but there is some driveline jerkiness when you are accelerating hard and switching gears. I definitely don't regret the CDV mod. Cars like this should not have the CDV <---training wheels.
08-12-2010, 11:16 AM | #24 | |
Rep 421
08-12-2010, 11:24 AM | #25 | |
Rep 114
I may not have been hard enough on the car while test driving it. One reason is that my wife has always been with me, that I can fix. The other one is that a few months back I was looking at a nice 2003 MSport 540 and while out on a test drive I pushed the gas pedal all the way down and about 3 seconds later I was blessed with a profuse amount of steam coming from under the hood. Turns out the plastic radiator decided to let go at the same time I wanted to feel out the car under full acceleration. So here I am in a car that is not mine, from a private seller and I have to call him to notify him his radiator is blown and I am on the side of the road. (I pulled over immediately). So I am still a little on edge about really pushing a car that is for one unfamiliar to me and two that I don't own. Now, the nice part is that I somewhat knew the guy and I did the right thing and helped him remove and replace the radiator that weekend but it still was not a good feeling... But the next time I am out in a dealer owned car I will be more "sporty" in the driving to see if I notice it. |
08-12-2010, 03:23 PM | #26 | |
Rep 615
08-12-2010, 06:49 PM | #27 |
704
This was a poor choice of words in attempting to be brief (posting via Iphone).
What I meant was that since the CDV is still on the car (rather than a delete) and the Zeckhausen looks stock, it's not going to raise any red flags at the dealer. I doubt any tech at the dealer would know the difference between stock and Zeckhausen anyway even if they looked. I've gone back and edited the prior post for clarity. |
08-12-2010, 08:17 PM | #28 | |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
08-12-2010, 08:57 PM | #29 | |
Rep 421
08-12-2010, 11:36 PM | #30 | |
Viper Driver
36
Rep 1,311
08-13-2010, 07:55 AM | #31 | |
Rep 421
I have a clutch stop set up for the release point a ~half inch from the stop. If you do a bleed and remove some air the release will go up higher. |
08-13-2010, 12:01 PM | #32 |
704
Makes sense. But the average tech? Maybe not so much? In any case, my information/reasoning was apparently flawed....
Is BMW flagging cars for just having the Zeckhausen or voiding the power train warranty? It wouldn't make a difference to me as I hate how the car drives with it and I'm willing to pay to play on that one, but I'm sure this might factor into other's decisions. I guess the core question is whether just having it will flag the car (are they actively looking); or if it might become an issue should clutch or transmission problems occur.... Any insight would be appreciated so we can take appropriate steps.... |
08-13-2010, 05:52 PM | #33 | |
Rep 421
08-13-2010, 11:02 PM | #34 |
Viper Driver
36
Rep 1,311
inspecting the zeckhausen and oem cdv's side by side, everything from the number etching to the machining looks almost identical, only difference being the significantly larger bypass area of the zeckhausen one. i'm quite sure that unless a in-the-know bmw tech removes the cdv and spots it to be a zeckhausen, there's next to no way to tell on visual inspection.
08-14-2010, 12:48 AM | #35 | |
Rep 250
Drives: '07 Imola Red Z4 MCoupe
~Krissi~ '07 Imola Red Z4 MCoupe
Eisenmann Sport Exhaust | RE X-Pipe | RE Transmission Mounts |
08-14-2010, 10:03 AM | #36 |
Rep 1,143
CDV made a night and day difference in drivability, especially for the heavy duty M clutch.
THe notchiness is common on this transmission, and as has been stated, has nothing to do with the CDV. In fact, I can feel it in my ZHP too (same ZF gearbox), but it's more subtle. |
08-14-2010, 10:42 AM | #37 |
Certified Adrenaline Junkie
43
Rep 1,325
08-14-2010, 12:41 PM | #38 |
Rep 421
08-17-2010, 12:44 PM | #39 |
Viper Driver
36
Rep 1,311
curious as well how the cdv may have helped the clutch feel itself. as far as mechanically understood, the cdv delete would only help engage the gears directly and immediately instead of the 'delay' the valve itself is meant to create in order to prevent 'shock' to the master cylinder?
08-17-2010, 01:11 PM | #40 | |
Bad Lieutenant
233
Rep 3,517
08-17-2010, 02:33 PM | #41 | |
Rep 527
A CDV is a valve that delays/restricts fluid delivery (and thus clutch engagement) to help circumvent the possibility of grinding gears and driveline damage due to aggressive or careless shifts. Prime example - 2003+ S2000s came with a CDV. It was quite a popular mod for people to remove it and while some were ok with the change, others were left with blown rear diffs and damaged gears as a result. |
08-17-2010, 02:41 PM | #42 | |
Bad Lieutenant
233
Rep 3,517
08-17-2010, 02:53 PM | #43 | |
Rep 527
I had an AP1 S2000 and I couldn't imagine having that car with one. My S2000 was heavily modified with an aftermarket clutch, pressure plate, built transmission, and built diff.. sooo my opinion of CDVs is a little skewed in that respect. I have contemplated doing the CDV mod in my Z4MR, but I haven't been really that unhappy with its current performance. |
08-17-2010, 03:06 PM | #44 | |
Bad Lieutenant
233
Rep 3,517
