      08-18-2010, 07:05 PM   #1
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
Torque specs needed
Getting ready to install shocks and springs - wondering if there are any good sources for chassis fastener torque specs? Am I looking at a Bentley manual to get this, or are there any online sources?
      08-18-2010, 07:22 PM   #2
scottyD
scottyD's Avatar
Drives: 07 3.0si Coupe
Check out eBay for the BMW TIS DVDs. They are the factory repair instructions and come with all tightening torques.
      08-18-2010, 08:33 PM   #3
MFGJR
Drives: 2007 Z4 M Coupe
In here?
http://www.zpost.com/forums/showthread.php?t=404222
      08-19-2010, 06:51 AM   #4
AWM3
BMW Fan
AWM3's Avatar
11
Drives: 2012 E92 M3, Alpine White
If you can't find the exact values here is a table of general torque values for metric bolts:
http://www.cncexpo.com/MetricBoltTorque.aspx
One thing to be quite sure of is the tightness of the bolts that attach the lower part of the front strut to the front hub assembly. They need to be really tight, and should be rechecked after driving the car for a while. Also, if the lower shock bolt in the rear isn't tight enough, it will gradually work itself loose and fall out. That won't strand you on the road but you would have to get another bolt.
      08-19-2010, 08:28 AM   #5
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
Originally Posted by MFGJR View Post
That is good. I think I will need a diagram to go with it - some of the descriptions are pretty vague. Can probably use diagrams from RealOEM to figure our for sure what is what.
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
