      12-08-2014, 11:46 AM   #1
Rodshopr
Drives: 2003 BMW Z4
Two different headlights
I have a 03 3.0i z4 and I believe before I got it that it was in a small front end collision who ever fixed it made a mess. I have xenon lights in the passenger side but the driver side has halogen. I would like to install the spyder halo headlights (which is a plug and play set) but I'm not sure how to install them since the plugs for xenon lights and halogen lights are different.
      12-24-2014, 03:35 PM   #2
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Ah, that definitely sounds like a mess! Personally, I'd have a shop take a look and confirm because when it comes to wiring that stuff, who knows what they could have done. I'm going to guess the car originally had HIDs and when hit, the body shop looked up replacement items and went with cheaper option.
If you enter the last 7 digits of your VIN here -> http://realoem.com/bmw/select.do and you go to the correct section, it will tell you which lights your car had from the factory. If you aren't sure, post up the last 7 digits here and I'm sure someone can pull it up for you. Knowing which it had from the factory may give you a lead on ease of replacement.
-Matt
