09-17-2011, 05:45 PM | #3 |
Rep 494
Did you have to run e36 studs (longer), or did the current ones work? GLWS
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit| |
09-17-2011, 05:53 PM | #4 | |
Rep 476
The shape of the headers allowed me to install and remove them without even using a universal joint on my 1/4" ratchet--just a single extension. |
09-19-2011, 09:54 AM | #6 |
Rep 1,855
Looks like a great deal to me! Someone pick these up or I'll get tempted
09-19-2011, 11:17 AM | #7 |
Rep 476
I have read reports both ways about it passing the numbers. I expect that if you did your due diligence and got the car nice and warm, going to the smog place immediately after some hard runs, it would absolutely pass the sniffer (actual emissions numbers). Visual wouldn't be too hard, because the headers are pretty well covered by the heat shield, but if the smog guy is a stickler he could fail you there. The problem is if your state does OBD-II port checks (like CA does), the computer probably will have some "readiness" codes--even though there is no SES light. At least, this was the case with the ESS tune; perhaps the ECS tune can eliminate this too. In short, I'm planning to swap back to my USDM headers for smog.
09-19-2011, 02:23 PM | #8 |
Rep 740
Thanks for the input. Yeah I'm in CA too (I actually met you at the dyno day, we had the matching cars, minus mine not having the supercharger) so I'm pretty wary of the mods I do and how they affect smog checks.
09-19-2011, 03:33 PM | #9 |
Rep 2,782
If your tune ignores the secondary O2's, it won't pass. I've heard ESS "turns down" the secondary O2's (and doesn't ignore their readings completely), but I can't verify it. You will have to ask someone at ESS about it. I would bet on - NO, it won't pass OBDII. I never had to go through a California inspection while I lived there, because I had the car exactly two years when I moved. Relocating the O2 sensors might tip off the visual inspector.
You could design an O2 simulator. I plan to make one once I get my SS V1 step headers put on.
09-19-2011, 03:40 PM | #10 | |
Rep 476
This has nothing to do with what the OBD-II port will tell you--as I mentioned, that will most likely show "Readiness" codes either way. But I still think it's possible to pass the sniffer numbers with just the secondary cats, with or without the secondary O2s, if you heat them up properly with hard driving before the test. |
09-19-2011, 04:13 PM | #11 |
///M-fanatic
193
Rep 3,885
I've got smog source, but need to triple-check on OBD2 & the addition of a tune. Not sure if Active Autowerk tune "turns down" the secondary O2 readings or if it "turns off" the readings altogether. I suppose I will be the test mule in a couple of years when smog is due
09-19-2011, 05:11 PM | #13 |
Rep 476
The usual answer to "is California that strict?" is "YES!" It's a risk to try to connect another car's OBD-II--it obviously transmits the VIN, which presumably the emissions control software and database will be looking for. Even if you found another Z4M to come along with you, you'd probably be effectively paying for their smog to be on file .
09-19-2011, 08:31 PM | #14 | |
Rep 2,782
I don't know about passing the sniffer beyond what others have told me - you will most likely pass by a very slim margin. You are removing your primary catalytic converters after all. OT - That being said, if I had to do it over again I would probably buy a quality set of headers that bolt up to the stock section 1- SS V2 or V2 step, AA, Euro, etc. I'm somewhat stuck in that it would be very difficult to modify the V1 step headers to fit my stock section 1, and I won't pay $2000+ for a catted SS section 1. If I go with an overpriced SS straight pipe, I will deal with rasp and an system that's more than likely deafeningly loud. If you don't need to worry about emissions, go for these headers.
09-19-2011, 09:05 PM | #15 | |
///M-fanatic
193
Rep 3,885
i.e. someone that's willing to turn more than an eye As of right now, the ONLY thing I'm not sure about is whether or not aftermarket ECU will cause failure of my smog. Everything else is not an issue |
09-23-2011, 02:47 PM | #18 |
///M-fanatic
193
Rep 3,885
09-23-2011, 03:50 PM | #19 |
Rep 476
As mfanatic says, yes--but the sound is nearly identical to the OEM Euro headers, and I find it overall more aggressive and throaty in a positive way. I have the stock Section 1, X-Pipe, and mufflers and am very happy with the improvement in exhaust sound moving to catless headers; it'll keep me satisfied for a while, especially since nearly all of our performance potential with exhaust modifications comes from the headers.
