      01-07-2012, 05:23 PM   #1
bdn3d
bdn3d's Avatar
92
Drives: Z4m Coupe/ Mini Cooper S
Have 20's?
Who here has 20's on their ride? Please share pics,specs, etc...
Good things may come to those who wait, but only what's left by those who HUSTLE!"
-George Washington
      01-07-2012, 05:27 PM   #2
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
there is a white roadster in the photos section on 20's. too big for a small car IMO but it looks good
http://www.flickr.com/photos/strasse...n/photostream/
      01-07-2012, 07:32 PM   #3
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
I tend to think even 19's look too big on a roadster, any kind of roadster at that (I had 18's on my TT roadster) but it really depends on the drop. My TT is bagged so it can pull off a bigger wheel without looking donked out IMO lol but I've seen moderate dropped Z's and TT's with 19's and thought to myself that's too big of a wheel.
So basically I'm saying it depends on the drop. When I pick up my Z4 I'll be looking for 18's MAYBE 19's after it's bagged.
      01-07-2012, 10:34 PM   #4
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
I tend to agree with you. I've been trying looking at a lot of pictures of Z4 roadsters with rims and trying to figure out if I should go with 18" or 19". Advice from different sellers have been inconsistent as well. Some will tell me 19" with low profile tires and a drop will look good. But I think at the end, for my car, 18" rims with the current brakes I have make more sense. Plus I don't think I want low profile tires and make the ride any bumpier than it already is.
      01-08-2012, 08:04 AM   #5
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
Id rather have 17's with MUCHO tire. :-)
      01-08-2012, 10:31 AM   #6
bdn3d
bdn3d's Avatar
92
From what I hear a 19 inch wheel and tire are good for the z but the tires cn be a bit more expensive due to the odd size, found wheels for my car but they only come in 20 so I was thinking of going that route, tires should be less expensive than 19 too. I'm just curious as to how many z post members here have 20's because I'm afraid they will be too big. Was going to go with h&r sport springs too but not sure at this point
-George Washington
      01-08-2012, 11:37 AM   #7
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
H&R springs and 20's are a bad combination. You are going to have to slam the car for it to look good on 20's. 19" tires are not expensive. I have hankook v12's on my street wheels and they are great
      01-08-2012, 12:18 PM   #8
DataStream18
Drives: 2003 ESS TS1 Z4
I have sport h&r springs on my Z and it (IMO) dumped it. I had to remove my spacers just so the wheels would not rub any more. 20's are way to big, you'd basically have to be rinning rubber bands for tires and thats with stock suspension. If anything 19's at the biggest! Also its going to depend on what you plan on using the car for, track? DD? those are the choices you have to make first before you get some new shoes.
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit.
      01-08-2012, 04:27 PM   #9
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
H&R spring lower the z4 more than the z4m.
