01-16-2012, 04:42 PM | #1 |
Rep 167
Headlight washers
Is there a way to tell if u have the headlight washers? I have those two covers on the bumpers near the the headlights so those that mean I have the washers?
01-16-2012, 05:17 PM | #4 |
Rep 335
You should see two pulses of fluid over your headlights when you squirt your washer fluid. It'll spray up and over the hood.
2007 ///M roadster |
01-16-2012, 05:29 PM | #6 |
704
If you're not the original owner, and you've never seen them spray, chances are someone disconnected them. That can be done via the fuse or by disconnecting the power to the headlight washer pump. Lots of us do this because the tops have a nasty way of disappearing when the washers are used.
01-16-2012, 06:15 PM | #7 |
Rep 1,663
They activate if you clean the windshield when your lights are on (auto or regular).
01-16-2012, 07:45 PM | #8 | |
Rep 421
01-16-2012, 11:29 PM | #9 | |
Rep 1,543
- Jeff
bosstones' flickr |
01-16-2012, 11:51 PM | #10 |
Rep 167
Thanks for the help! I just tried them and it works even though they seem like they are useless in sunny California. It sprayed my headlights and hood.... :/
01-17-2012, 08:49 AM | #11 |
Rep 4,531
01-17-2012, 10:43 AM | #12 |
Rep 1,855
I don't even like spraying my windshield with washer. . . Usually it can wait until the next car wash.
Say I'm weird, but I run with the washer a little above empty (so it doesn't trip the washer fluid light) to save that extra few pounds of weight. =)
01-17-2012, 10:57 AM | #13 |
Rep 33
I use mine up here in the winter. Really does make a difference at night.
2007 BMW Z4 M Coupe / Black Sapphire Metallic
Advan RS-D / Michelin PSS Shrick 288/280 Cams / Multi-Angle Valves Fabspeed Headers |
01-17-2012, 11:41 AM | #14 | ||
704
01-17-2012, 12:33 PM | #15 |
Rep 4,057
It strikes me as odd that BMW decided to equip the Z4 M with headlight washers, but not the foglights that other Z4's are equipped with. Living in an area where fog is very common in the spring and early summer, I'm quite happy to have the fog lights.
Ad yes - I have seen several late model 3 series cars in the parking lot at work recently, and I did notice that bits of the headlamp washer seemed to be missing on one of the cars.
Huz-Z
02-26-2012, 09:59 PM | #16 |
Accidentally in BMW
15
Rep 221
02-26-2012, 10:19 PM | #18 |
Rep 1,097
found out when i accidentally turned my washers on in the garage. I had a HUGE mess in front of the washers and on the hood, didnt even think about it until that moment.
02-26-2012, 10:23 PM | #19 | |
Member
15
Rep 178
02-27-2012, 07:26 AM | #20 |
Rep 2,138
Drives: Me
You can pull the fuse (#40 as Kgolf31 states), or you can disconnect the electrical connector to the headlight washer pump. Either one works.
02-27-2012, 07:59 AM | #21 |
Rep 99
Drives: 2007 z4 3.0si Coupe
Please allow me to show my ignorance (again... ) but aside from the headlight washers spraying the hood, do they actually really even do much good w/o blades? We had a MB once upon a time and even with blades the washers were of little value IMHO. More of a 'smear' than a 'clear' if you know what I mean. So I'm not really seeing how just shooting a small stream of water at a headlight is really going to help that much.
Am I wrong? Rus |
02-27-2012, 08:12 AM | #22 |
Accidentally in BMW
15
Rep 221
The one time I watched it do what it is supposed to do (from outside the car).... a serious blast of water shot directly onto the headlights and cleaned off all the road dust. I was impressed.
Clean headlights are safer/brighter I guess and they also last longer (so say experts elsewhere in this forum) because they stay cooler without the insulation of accumulated dust and dirt. Mine seem to work just fine. Last edited by EenyBear; 02-28-2012 at 03:18 PM.. |
