02-16-2012, 09:45 PM | #1 |
Rep 11
Z4 Manual Shift to 2nd ???
I picked up an 07 Z4 with 20,000 miles. Shifting to 3/4/5/6 is smooth , but the 1 to 2 shift and the 3 to 2 shift is notchy.
Is this common ? Can this be cured with an adjustment of the shift cable ? Anything I'm missing ? |
02-16-2012, 09:50 PM | #2 |
Rep 1,546
There's so many threads about this. lol Welcome to the fam! Do you have an M or what? The M crowd will tell just slow down your shift from 1 > 2 and pull down and slightly left. Don't try to throw it into gear and you'll be fine.
02-16-2012, 09:58 PM | #3 |
Rep 11
Not an M , just a nice street roadster.
I'm usually pretty EZ on the shift ( I've never even killed a miata gearbox on the track ) , but it's still annoying. I'll focus on the slightly to the left move and see if it helps |
02-16-2012, 10:04 PM | #4 |
Rep 11,667
have a look at this thread.....
http://www.zpost.com/forums/showthread.php?t=524589
02-16-2012, 10:50 PM | #5 |
Rep 421
02-17-2012, 12:52 AM | #6 |
Rep 2,866
I find that shifting at relatively low revs exacerbate the problem. Try shifting at 4K to 4.5K should be much better.
02-17-2012, 02:36 PM | #8 |
Rep 1,855
this problem is common on the M cars. Never heard of it being much of a problem on the non M however. Transmission mounts and transmission oil seem to help, as does slowing down the shifts into 2nd. Other than that, it is a design flaw, and there's not much you can do to "fix" it...only mitigate.
02-17-2012, 03:25 PM | #9 |
Rep 2,866
02-17-2012, 04:10 PM | #11 | |
Rep 541
Drives: 2022 X3MC
btw, 37k on ODO |
02-17-2012, 04:58 PM | #12 |
Rep 100
02-17-2012, 06:12 PM | #13 |
Rep 784
Drives: 2011.5 E90 M3
I STILL don't know what notchy feels like. 1-2 is just like every other gear change to me, very crisp.
02-17-2012, 06:27 PM | #14 |
Rep 162
my NON M 3.0i is like this going into 2nd but pretty bad going into 3rd. It like sometimes going into 3rd, I am acutally blocked from doing so.
what does the dealer do if you complain about such things? |
02-18-2012, 01:21 AM | #15 |
Rep 2,866
They will most likely tell you that it's either "normal" or "can't duplicate".
02-18-2012, 07:22 AM | #16 |
Rep 99
Drives: 2007 z4 3.0si Coupe
Personally, I don't experience this problem but I'm familiar with others talking about it and ironically, it seems the original owner experienced the problem as well. What's weird about all this in my case is that when I bought the car he provided me with every piece of documentation ever printed, from all original paperwork to every service. When I started looking at the service receipts I noticed he had complained about the same thing when the car only had like 1k miles. His dealership (BMW Nashville) actually replaced the entire transmission! lol I'd done a PPI on the car but to tell you the truth, had I known about the tranny replacement I might have started fretting about the transmissions in the Z4. So sometimes I guess ignorance is in fact bliss.
Russ |
02-19-2012, 01:58 PM | #17 | |
Rep 162
3rd for me, if I try to shift between say 2700 and 3100 rpms. forget it, it justs hits a wall and I have pull the stick back and then just shove it forward again or rev it up higher. I'll probably take it at some point and see what they say while it is still under the extended warranty. |
