      06-25-2019, 08:27 AM   #1
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Skyer skirt extension install
The install instructions provided stated to use self tappers, however after some spirited driving lost one tapper and noticed another on the floor when I did a walk around meaning with vibration they could pull off.
Decided to go with aluminum rivets. Drilled hole as per rivet size and added a 1/4 inch 1"x1" aluminum plate for added support to mounting holes. Ended up being a more secure way of attaching the extensions.
      06-26-2019, 07:48 PM   #2
Mirko
Mirko's Avatar
My side skirts are attached with aluminum rivets as well.
      06-27-2019, 08:12 AM   #3
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
The actual side skirts or the extensions?
      06-27-2019, 07:10 PM   #4
Mirko
Mirko's Avatar
lol .. the carbon fiber extensions
