      03-19-2018, 07:08 PM   #1
mainsoda
mainsoda's Avatar
Drives: 2006 BMW Z4M coupe
Upgrading expansion tank
I was watching a BMW channel and the guy had a M5 that needed a new coolant expansion tank. He upgraded to a metal tank because these are a known fail point. That got me to thinking if any of you have done this on your S54.
Would it be worth it? Is there a downside to a metal expansion tank?
      03-28-2018, 01:20 PM   #2
RevsPlease
Drives: 2003 Z4 3.0i, Black Saphire
2003 BMW Z4 3.0i  [10.00]
Never seen it done on a Z, but there are several E46 threads out there experimenting this.
I believe Mishimoto was making an aluminum replacement but it was of poor fit/quality and was discontinued. There is however an outfit called Zionsville Autosport selling a comp radiator and expansion tank setup for E46; you might try contacting them about a solution for the E85/6
https://www.zionsvilleautosport.com/...g-kit-1999-05/
mainsoda171.50
      03-28-2018, 07:52 PM   #3
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
They can fail due to the plastic getting brittle over time. The easy solution is just to replace it with a new "fresh" tank.
mainsoda171.50
      03-28-2018, 08:01 PM   #4
StickMon
StickMon's Avatar
Drives: 2006 MR
And don't forget about the plastic line.
I expect mine to shatter into a thousand pieces one of these days.
Zionsville radiator and expansion tank and braided line would be the hot setup.
Pun intended.
mainsoda171.50
      03-29-2018, 11:56 AM   #5
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
This doesn't seem to be a big problem with the Z4, at least not yet. On the E46, it's almost a right of passage to replace the entire cooling system. They also replace the exp tank cap with one that vents at a lower temp/pressure, as some think that something goes wrong and causes a pressure spike, and that is what causes the exp tank to fail. I actually have an exp tank, hoses, transmission thermostat, new water pump, etc. ready to go into my son's E46.
mainsoda171.50
      04-01-2018, 06:54 AM   #6
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
My tank showed no signs of leaking or loosing coolant last year, on a long drive out of state, coolant tank blew into pieces....had no choice to bring it to nearest stealership to get fixed. Preventative maintenance part.
StickMon636.00
      04-01-2018, 09:35 AM   #7
dre99gsx
Drives: 1994 Toyota Supra
I went a separate route and got rid of it - went to an old-school metal water bottle where the overflow just dumps into it. Couldn't believe the extra cost involved with a oem-replacement or even an 'upgraded' replacement.
I have images of it in my 2JZ build thread if your curious. May not be for everyone...
StickMon636.00
      04-01-2018, 09:57 AM   #8
2282
That sucks... how many miles at the time?
      04-01-2018, 10:23 AM   #9
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Definitely did, happened somewhere between 89-93k
      04-01-2018, 11:59 PM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
Thanks. Something new for me to worry about.
I sit in stop/go traffic in 100°F+ heat and have 173k miles.
I can totally picture tank shards all over the place.
Adding tank and line to my next bulk parts order.
Can you believe I'm still on my original water pump?
      04-02-2018, 01:31 AM   #11
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
      04-02-2018, 04:21 AM   #12
Beedub
tbh these have lasted so long, i think during a service just drain coolant and replace with a new stock one, replacing these one every decade is reasonable imo.
      04-06-2018, 12:03 PM   #13
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
I have gone through 2 expansion tanks in five years of ownership on my 3.0i. The first cracked and I ended up doing a cooling system overhaul a couple of years ago (thermostat was also cracked) and another just a few weeks ago.
To be fair, it is outside in the wild year round so it is subject to the crazy weather we have in the Chicago area, so I regard the expansion tank cracking as just part of the territory for me using a Z year round!
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      04-06-2018, 12:35 PM   #14
SaltyNC
SaltyNC's Avatar
370
Oh man, yall quit posting these expansion tank failures. I thought we were immune to this blight that other BMWs suffer. I'm putting my head back in the sand.
      04-07-2018, 10:18 AM   #15
The HACK
The HACK's Avatar
1821
Tank size/shape is unique to our cars. E46 S54 expansion tank won’t fit. Z3 S54 expansion tank will.
They’re not excessively expensive. I plan on doing mine this summer for peace of mind, but there are no direct bolt-on aluminum replacement units on the market so I’ll be replacing with OEM.
