      05-14-2013, 06:16 PM   #1
Lennyzcoupe
Drives: Z4 3.0si Coupe
3.0Si Front splitter/lip install
Hi guys. I could not find any other 3.0 with a lip/splitter. So I decided to post some more pictures of mine. I got it installed last thursday and I'm still very happy with it. The fitment was good, however it could have been a bit longer in the back towards the wheel arches. Other than this it was perfect. And I would gladly recomand it! Here is a link to the sight I got mine from. --->http://www.eurotuningshop.com/produk...rd-bumper.html
Picktures is taken with my Iphone 4s, not the best quality.
Here we go.
Fitting
The only mod we had to do was to cut this small groove in the splitter. To keep it from hitting a screw. Otherwise perfect.
Here are the results
Height measured in iphones...
Her is a video of me trying to cross a speed bump... https://vimeo.com/65836893
      05-14-2013, 09:30 PM   #2
ProdigyM
Prodigy
ProdigyM's Avatar
Jamaica
Drives: 2000 Honda S2000
looks great! i actually wish it stuck out farther in front of the bumper
nonetheless great mod!
:thumbup:
Christopher Williams
-The Prodigy
      05-14-2013, 09:42 PM   #3
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
Looks great!
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      05-14-2013, 10:18 PM   #4
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
Looks great! I'm sure it would look awesome with my AW roadster. I agree with ProdigyM. If it stuck out just a little more it would be perfect!
      05-14-2013, 10:28 PM   #5
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
I need something like that for my
View post on imgur.com
      05-14-2013, 11:02 PM   #6
norcal_cyclist
Drives: 2006 Z4 3.0si
1999 BMW 323i  [0.00]
I'm trying to get a GB together for that lip.. check the classifieds
      05-15-2013, 06:40 AM   #7
Lennyzcoupe
:thumbup:
Thank you!
I agree, but it is hard enough to get over bumps as it is. So i think it is the best of both worlds.
3002 tii2298.50
      05-15-2013, 06:41 AM   #8
Lennyzcoupe
Originally Posted by K3N R3D View Post
Looks great!
Thank you!
      05-15-2013, 06:43 AM   #9
Lennyzcoupe
Agreed! But still better than nothing!
      05-15-2013, 06:48 AM   #10
Lennyzcoupe
Yes you do!
      05-15-2013, 06:50 AM   #11
Lennyzcoupe
You have to explain this better for me.. Sorry.
      05-15-2013, 07:34 AM   #12
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
Anything like this in CF for our non-M Z4s?
      05-15-2013, 08:00 AM   #13
Lennyzcoupe
Not that i know of. This is the ONLY one i could find But you can always wrap it in "carbon" If you do that you can bild it bigger as well
      05-15-2013, 09:07 AM   #14
Incompatible
Drives: 07 AW Z4C 3.0Si
Originally Posted by Lennyzcoupe View Post
.... The fitment was good, however it could have been a bit longer in the back towards the wheel arches. Other than this it was perfect.
Have you got pictures of the side showing the fit at the wheel arches? Thanks
      05-15-2013, 10:26 AM   #15
Lennyzcoupe
It looks good here, but to make it fit right on both sides we had to move it forward...
This is how it looks. Not too bad, but it could be better.
      05-15-2013, 12:02 PM   #16
CJW2OO4
CJW2OO4's Avatar
could someone please photo shop the center part of the bumper black? I am curious how that would look with the splitter.
      05-15-2013, 12:25 PM   #17
Incompatible
Thanks for the side pics. Is your Z suspension (ride height) standard, M Sport, or aftermarket (springs Eibach, H&R....)? Also tire sizes? I'm lowered on Eibachs with oe tire sizes, driveways could be a problem.
      05-15-2013, 12:59 PM   #18
Huz-Z
Huz-Z's Avatar
Wow!!
Looks good!! I'l have to check out the group buy you mentioned.
Huz-Z
      05-15-2013, 02:30 PM   #19
psygnosis
psygnosis's Avatar
23
The 2003-2005 Z4 with the Sport Package is the lowest stock Z4 (even lower then the Z4 M) His car is lower then that.
      05-15-2013, 05:47 PM   #20
Lennyzcoupe
I run H&R lowering springs. 35mm. My wheels are Lm.reps 235/35-19 and 265/30-19 Et35 front and rear. I need to change my fronts to 225 they are rubbing a bit in the inner wheel arches..
I don't think this will be much of a problem, your Eibachs lowers the car less than mine. (I think 5-10mm ish) And i can still enter ferries and stuff. But too much of a steep angle and you will scrape. But even though it sounds bad i have no marks in myne yet.
Steep speedbump https://vimeo.com/65836893
I am impressed with your knowledge. I didn't know this. But it sounds like you know your stuff. And yes my car i lower than that
      05-15-2013, 05:51 PM   #21
Lennyzcoupe
Originally Posted by Huz-Z View Post
Wow!!
It sure does. I am very happy with the result. Much angryer, and more racecar-like.
You should definitely look into that
      05-15-2013, 07:14 PM   #22
Incompatible
Thinking about it. Compared my iPhone bumper height with yours, looks like you're about 3mm lower than I am. My problem is with steep driveways at work and home.
