11-21-2012, 07:00 PM | #1 |
Rep 1,543
Lights flashing and radio cut out?
I got ABS, Hand brake and Traction control light all flashing at the same time on the dash and the radio volume cuts out. Each incident only last less than a second. Everything then back to normal.
This happens 5 ~ 6 times within a 5 min period. I faintly recall that a month back this happened as well. Anyone have any similar happening to them or any guesses where I should start looking? 07 with Navi. TIA, |
11-21-2012, 08:59 PM | #2 |
704
Rep 7,850
Original battery?
I'd start there. Check the connections for tightness/corrosion. Bit if it's the original battery that's probably the culprit--have it checked. |
11-21-2012, 10:48 PM | #4 |
Rep 1,543
Got a new OE battery before warranty expired last year. Had the symptoms before the dealer gave me a free one.
I don't think it's the typical battery issue where random lights come on since all lights are brake related. Had that issue before and I just got new pads 3 months ago. Rotor looks fine and radio cut out? That's what really throws me off.. |
10-12-2013, 10:42 PM | #6 |
Rep 1,543
Yes, one of the radiator wire came lose acting as low/weak battery. Once reconnect it properly. No symptoms for the last 11 months.
HTHs, |
