      02-22-2015, 10:10 PM   #1
MPowerZ32
MPowerZ32's Avatar
66
Drives: Man
Vented hood for supercharged Z4M?
I have the non-intercooled ESS supercharger kit. I have been noticing a slight idle hunting (oscillation) on warm days. As soon as I open the hood the idle stabilizes, or at least it appears to behave that way. This leads me to think under hood temperature plays a role. I think I could benefit from venting some heat from the engine bay. Or maybe I'm completely wrong on this theory. I'd like to hear your opinion. The car drives completely fine otherwise.
      02-25-2015, 04:01 PM   #2
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
Sounds like you need to upgrade to the intercooled version! Or upgrade your oil cooler. Or both!
I doubt a vented hood would do much but you could play around with adding the RPi air scoop and eliminating your side markers for some air flow.
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
      02-25-2015, 04:07 PM   #3
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
my idle isn't perfect every time on my ess kit either
      02-25-2015, 07:27 PM   #4
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
My ESS kit idles at varying rpm, but it's always stable. Can you describe the hunting idle in more detail?
The intercooled version won't help you, as it's air-to-air and only works when you have airflow passing over it.
      02-25-2015, 08:46 PM   #5
MPowerZ32
MPowerZ32's Avatar
66
Drives: Man
The idle isn't bad. In warm days the idle RPM sometimes varies about 100-150 rpm. The needle doesn't want to settle. It just goes up and down a bit. The oil temp has always been normal though, even at the track. The under hood temp is very hight though in warm days after a drive. I'm not sure what's causing the idle hunt, but opening the hood seems to help the RPM to settle.
      02-25-2015, 09:10 PM   #6
nesrevival
nesrevival's Avatar
28
Drives: Z4MC 07'
When did you install??
2016 MK7 GTI PP LP DCC
2015 Macan Turbo Ordered!!!
http://www.porsche-code.com/PF1XIUS5
Gone: 2007 Supercharged ESS VT-525 Z4MC
      02-25-2015, 11:00 PM   #7
MPowerZ32
MPowerZ32's Avatar
66
Drives: Man
I've had the kit for about 2 years, 10K miles. It's been very reliable apart from the idle hunt. It looks like ESS revised the manifold. I have the old version...
      03-01-2015, 01:35 PM   #8
Beedub
yeah they made it slightly smaller, I'm happy with the larger version actually tbh, my logic tells me it holds a higher volume so that can't be a bad thing, not that it matters on FI.
my idle is perfect BTW, never been an issue, infact it idles better than it ever did stock.
here a video from a while back. Jump to 1.55. This video was taken while the car was stone cold, and it still idles like this to this very day. Why not ask ESS to update your tune ? or possible ICV issue maybe?
