      08-31-2011, 03:54 PM   #177
Z4-PM
France
Drives: Z4MC
Will this setup fit on Z4MC with stock suspension and later lowered 1/2" on KW Clubsport:
F: 19x8.5 ET35 on 245/35/19
R: 19x9.5 ET20 on either 255/35/19 (perfect diameter) or 265/35/19 (1% bigger)
Z4MC / ZR CDV / G-Power exhaust / RE X-Pipe / GruppeM / NGK Irridium plugs / Sport System ECU / RE RTABs & RSMs / Bilstein B12 / VMR VB3 Michelin PSS / M Strut / AP Racing 6x4
      09-03-2011, 04:57 PM   #178
apexstrafer
Drives: Z4 M Coupe
Yes.
      09-05-2011, 05:22 PM   #179
sho-one
MMA fighter and F1 test driver
Drives: Z4///M coupe bulletproof
19x8.5 30 +6mm inside + 18mm outside
19x9.5 22 + 2mm inside + 14mm outside
will these fit stock without rubbing?
NOW:08 M.Coupe SMB #102/248 #1669/1815
:|MORRVS8|APEX8|SS.X-pipe|SS.PW.Loop|AFE.intake|Matte.grill|short.ant|Z HP.knob|interior.LED|bulletproof
09 Audi Q5
THEN:96Accord|98Camry|04TSX SC|06 M3|06A4|05Civic Si|05Imprezza|05S2000|08FJ
      09-06-2011, 12:29 PM   #180
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Almost exact same specs up above.............
      09-06-2011, 01:57 PM   #181
sho-one
lol sell me your wheels =P
09 Audi Q5
      09-06-2011, 07:28 PM   #182
mfanatic325
///M-fanatic
Taiwan
193
Please obtain a ticket, and wait in line
There's a set for sale in the classified section! From Joe Chu, from SoCal (southern California).
      09-23-2011, 10:20 PM   #183
mpower1226
Drives: Audi TT
Can anyone verify these fittings?
I've already paid for it and picked it up but didnt bother putting them in yet.
they are out of 335d , miro type 111 hyper silver
front is et35 19x9 with falken fk452 225/35/19
rear is et33 19x9.5 265/30/19
What do you think, I know rear would fit perfect, but the front? rub?
It is stock suspension and do not intend to lower it.
What y'all think?
      10-05-2011, 02:10 AM   #184
vortex_tuning
Drives: E92 M3
Not sure if you are trying to install the wheels on an M or non-M.
The front should fit both M and non-M. For the rear to look good on an M you will need spacers (10 - 12mm). No spacers needed for non-M.
      10-16-2011, 12:12 PM   #185
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Will this setup fit on Z4MC with stock suspension and stock camber settings:
F: 19x8.5 ET32 on 245/35/19
R: 19x10.5 ET25 on either 275/30/19
I don't want any other modification to make them fit. Been eyeing some BBS CH-R's. Tirerack list this fitment as compatible with the Z4M. I have not seen anyone having these fitted on a Z4M yet.
      10-16-2011, 07:08 PM   #186
mfanatic325
///M-fanatic
Taiwan
193
The rears will require fender roll and not too low of a suspension drop in order to clear. Otherwise the 275s will rub. Other than that, the wheels fit. G'luck!
      10-16-2011, 11:28 PM   #187
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Thanks for the confirmation. I was hoping that no fender rolls would be required Guessed that's why I haven't seen an E85/E86 rockin these. I thought TireRack were pretty good with their fitment guide, that is, they wouldn't recommend anything that requires additional body modification to make them fit
      10-17-2011, 03:02 PM   #188
mfanatic325
///M-fanatic
Taiwan
193
If you are planning on lowering the car quite a bit AND running 275s, then the roll is needed. Otherwise, you may get off with 255s or 265s at most, with no drop.
10.5" rear with low-20s offset is just too aggressive for the stock fenders. It's unfortunate that BMW didn't give the M models wider, more distinctive fenders
      10-20-2011, 02:59 PM   #189
aftercorbu
aftercorbu's Avatar
Drives: 20 M2C, 20 S3
edit... found the non m thread at http://www.zpost.com/forums/showthread.php?t=398990
      10-26-2011, 01:26 PM   #190
Mirko
Mirko's Avatar
Was test fitting some 17" x 8" rims for a winter setup. Not sure of the offset, square setup. Had no issues with the brakes. Decided to just use my stock wheels and get Blizzaks but wanted to share that 17's can fit.
      10-26-2011, 02:18 PM   #191
mfanatic325
///M-fanatic
Taiwan
193
^ haha, I guess that's one way of getting out of having to get BBKs as far as the aesthetics goes
      10-30-2011, 07:13 PM   #192
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
How about these?
18x9.5 ET25
18x10 ET20
Looks like a no...
2006 Z4MC - #LL93158
      10-30-2011, 07:35 PM   #193
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
Too aggressive in front. It will stick out the fenders and rub unless you put a serious amount of camber, but then it will also look broken. The rears will fill, but need rolled fenders and some camber adjustment to avoid rubbing
      10-30-2011, 10:52 PM   #194
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I run 18 x 9 et 35 front, and thats pretty close to the strut towers but if the fenders are rolled I probably have 5mm more to go there
      10-31-2011, 11:50 AM   #195
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Was a sweet deal on a set of used Advan's too.. Oh well.
      11-08-2011, 11:07 PM   #196
wyatth
Drives: E90 ZCP
18x8.5 +29 with 235/40/18
18x9.5 +23 with 265/35/18
Seems like they will be based on some posts in here. These are OEM E9x wheel dimensions, but a search for these wheels (limited results) says they are pretty damn aggressive ..
      11-08-2011, 11:48 PM   #197
mfanatic325
///M-fanatic
Taiwan
193
These will fit easily. Both the fronts AND rears. Have fun
      11-09-2011, 12:03 AM   #198
wyatth
Drives: E90 ZCP
Thanks for the quick reply. I too thought they would fit comfortably based on specs in this thread. Just bizarre that in application, members said they were running -2.5 front camber to fit. Cheers
reference:
http://www.zpost.com/forums/showthre...=e9x+m3+wheels
