12-16-2013, 10:56 PM | #1 |
Rep 12,565
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.22] |
Does Your Trunk Trim Have a Foam Pad?
I had to order replacement trunk trim and it came with this foam pad stuck to it. Was this just for shipping purposes or is this supposed to be installed together? Not sure because the foam isn't very secure, the glue dried out in some areas and it's pretty simple to pull out. Plus my original piece doesn't have anything behind it but wasn't sure if this was a part number revision -- maybe to address some creaking issue or something
12-17-2013, 06:08 AM | #4 |
Rep 704
Drives: '08 MC
hard to tell on my phone, is that the floor mat or the bulkhead wall cover? regardless, I've pretty much taken my entire trunk trim taken apart and dont recall seeing that foam. might be a weight reduction attempt in the M versus a 2.5 or 3.0 though....
12-17-2013, 06:43 AM | #5 |
Rep 12,565
It's the trim on the side that covers shock towers.
