05-08-2012, 11:14 AM | #1 |
Rep 615
Help with StopTech BBK
I want to get a StopTech BBK for my M Coupe but have a couple of issues. First, one of the dealers is saying on their ordering site that the 355mm kit with ST-40 calipers (recommended for this model) does NOT fit OEM 18" wheels. Is that right? Do the ST-60's fit? I've used their template and it looks to me like they will clear as long as there are no wheel weights placed in line with the calipers. I'm willing to go with either one but I'm not willing to get new wheels to accommodate this upgrade.
Thanks in advance for your help.
05-08-2012, 11:37 AM | #2 |
Rep 11,665
I have st60 front & st40 rear.
I have never tried them with an OE wheel but can do a test fit for you on the weekend if someone else doesn't chime in..
05-08-2012, 11:55 AM | #3 | |
1817
Rep 5,337
However, the profile on a fixed caliper is different than a sliding caliper, there's more "hardware" radially on a sliding caliper while there's more hardware axially on a fixed caliper, so a 355mm with fixed caliper may still fit if the profile of the fixed caliper does not interfere with the spokes of the wheel. On my E46 I had BBS RGRs and those would require a 8-12mm spacer just to clear the UUC big brake kit using Wilwood calipers, and the Wilwood is on the smaller side. And the stock wheel did not clear without a 5mm spacer. I would think that, due to the high negative offset of BMW wheels, that spoke interference is definitely an issue without spacers. If the front wheel/spoke design comes with a 38mm offset it probably would clear the 355mm fixed piston kit.
05-08-2012, 09:23 PM | #4 |
Rep 615
After further review with the templates on the front wheels (I used back wheels yesterday), they will not clear the factory 18" wheels without spacers. To me it looks like I probably need 12mm spacers to get enough clearance for the calipers. Anyone see any problems with this?
05-08-2012, 11:44 PM | #5 |
enthusiast
48
Rep 1,695
If it helps, Paintpro said that I need 5mm spacers with his 18 x 9.5 eta 35 front arc 8's to clear my stoptech's. Have not installed yet, otherwise I could give you more info.
05-09-2012, 12:47 PM | #6 | |
1817
Rep 5,337
Regardless, it would NOT be my choice to move the wheel out 15mm, since it can potentially have a very negative effect on the scrub radius. However, if this is strictly for appearance sake, knock yourself out.
05-09-2012, 03:19 PM | #7 |
Rep 615
Wow, I'm getting depressed by these clearance issues. Is there anyone on the board who has a BBK using stock 18" wheels and if so, what did you have to do to get them to fit?
05-09-2012, 04:17 PM | #8 |
enthusiast
48
Rep 1,695
If breaking faster is an issue, have you tried different pads with the stock set-up? Why do you need a bbk, but still have stock wheels?
05-09-2012, 10:16 PM | #9 |
Rep 615
This car has had problems with rotor runout (vibrations), with the original owner as well as me, even when there has been no track time. It has probably had 7 sets of front rotors during the 4-year warranty period. I have bedded the new brakes (per Zeckhausen instructions) and it still has done it. The dealer has tried to find the cause but says that all brake components are working properly. However, each time they drove the car and measured the runout and agreed that the rotors should be replaced. During the 4 years of warranty coverage, they were unable to determine the cause. All 7 sets of rotors were paid for by BMW. However, the car is now out of warranty and I thought a BBK might fix the problem once and for all. I've posted this problem on this board and it seems no one else has had similar problems.
05-10-2012, 02:30 AM | #11 |
Rep 503
Drives: Z4 M Coupe
I have the ST-60 front and ST-40 rear kit with the 355x32 rotors on OEM Z4M wheels. They would not fit without spacers as the callipers were making contact with the wheel spokes. My shop tried them with a 12mm spacer set they had there and they were able to install them.
The rears could be installed without spacers but i wanted the same extra offset all around so I bought 4 12.5mm Turner Motorsport spacers and it now fits just fine. No rub either. http://www.turnermotorsport.com/p-12...cers-pair.aspx
05-10-2012, 10:30 PM | #12 | |
Rep 615
05-10-2012, 11:46 PM | #13 |
Rep 503
Drives: Z4 M Coupe
No vibrations or other issues and i've already tracked the car once.
One more thing though... I might have been too quick to say it doesn't rub.. I just noticed these so it might rub in the front afterall...
05-11-2012, 05:56 AM | #14 |
Rep 11,665
Yeah, we all get rub in that circled area.
It's an easy fix with a heat gun though.
05-11-2012, 06:22 AM | #15 | |
Rep 11,665
05-11-2012, 01:31 PM | #16 |
Rep 615
I understand and I don't disagree with you. But the way I look at it, if I can fix this issue, I'll probably keep and enjoy the car for several more years. If I sold or traded the car, I'd probably spend double or triple what I could sell this car for and still might not like it as much. Since the "experts" can't seem to find anything specifically wrong with my brake system I thought might be a good way to both fix problem and make a nice upgrade at the same time. Sure, there is a risk that it may not work and if that happens, you'll be seeing a barely used BBK in the classifieds. In the meantime, I'm running out of other ideas.
05-11-2012, 01:50 PM | #17 | |
1817
Rep 5,337
05-11-2012, 03:32 PM | #18 | |
Rep 615
05-11-2012, 03:58 PM | #19 |
Rep 11,665
