03-13-2011, 11:29 PM | #1 |
Rep 255
**!!! To Those with H+R Coilovers !!!***
Hey Guys, I don't know if this is an isolated issue with just the H+R Coilovers, or if it crosses over to other brands..
I have had my car up on jackstands this weekend playing under its skirt (). Well upon inspection of my H+R Coilovers I installed about a year ago I noticed something was clearly not right. My Passenger side rear lower shock mount had started to work its way through the rubber bushing almost completely falling off!! I am almost positive if I would have driven another few hundred miles I would have lost the shock.. I'll let the pictures do the explaining here.. Please go out and check your shock mounts to make sure no body gets hurt!! I am currently coming up with a washer system to stop this from happening again, which I am really suprised that they didn't originally come with the kit.
03-14-2011, 12:26 AM | #2 |
Rep 1,269
Faulty install. The shock should've been turned 180 degrees where it's bolted to the sway bar mount.. Or there should've been a big washer used precisely to prevent what would happen in your photo.
2019 Porsche 911 4 GTS
03-14-2011, 12:38 AM | #3 |
Rep 255
Thought of that too.. but there is no washer on the other side either.. I did not have a washer come with the kit.
It would have to be a special washer anyway. If you would place a washer on there it would stick out a good 1/8" from the actual bushing anyway. I am trying to find some bigger washers that I can cut to size to fit over it, I'll post pictures to explain what I am talking about when I find it.
03-14-2011, 10:18 AM | #4 |
Rep 637
My Koni Yellows, sourced through GC, have a large "washer" or flange that is attached to the steel sleeve through which the bolt goes to prevent this from happening.
See pic Not faulty install, faulty design....
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint Last edited by onebluemcm; 03-14-2011 at 10:29 AM.. |
03-14-2011, 02:06 PM | #5 |
Rep 715
are u sure u got the right coilovers for your car?
it only says Z4 on the labal of the shock
RPI scoop|BMC drop in filter|EAS V1 aluminum mount|ZHP shiftknob|RHO plate holder|matte black grill|LED interior & license plate light|RE SSK|RE tranny mount|UUC engine mount|Bavarian CDV|clutch stop|18" Forgestar CF5 GOLD|RPI exhaust|H&R coilovers| RE RSM|
coming soon: aFe intake|tune|secondary cat delete| |
03-14-2011, 02:33 PM | #6 | |
Rep 255
Given that we have the M3 rear sub assembly I am assuming that I would have to have the correct setup. Can anyone crawl under their car and take a look at one of thier H+R shocks to verify?
03-15-2011, 02:58 AM | #7 |
Rep 715
this is a picture of my stock rear shock. there seem to be a plate/washer in place to hold it in place. did u forget to put that on or it won't fit with it on? sorry about my noob question. just trying to help out and took this picture while i was adjusting my exhaust today.
03-15-2011, 09:47 AM | #8 |
Rep 2,737
yea even my MINI has a 3 sided washer in their that keeps it from waking out.
i think thats whats missing, ive never seen a car with just a bolt holding on the grommet/shock, thats a garanteed failure. |
03-15-2011, 10:02 AM | #9 |
Rep 255
The stock shock has that plate attached to it, there is not attached washer.
I really wish someone with H+R's would post up a pic of thier lower shock mount to verify... I may just give H+R a call..
03-15-2011, 10:19 AM | #10 |
Rep 255
so a little research shows that the "washer" you are referring to is actually part of the shock assembly. it cannot be removed and transfered to another shock. See the attached Image.
I have a call into H+R right now and am just waiting to hear back.. I'll post my findings!
03-15-2011, 11:55 AM | #11 |
Rep 255
ok.. so I guess my case isn't isolated, there have been previous calls into H+R about missing washers. I have a no-charge set being shipping out to me today!
So please take a look at your H+R's and make sure you have these washers, if not call H+R and get them! (they are special washers).
03-15-2011, 02:44 PM | #12 |
Rep 715
thanks Rated M, i was planning to get this setup after have the H&R spring on for a while first!
kinda tight on money as a full time student and part time worker LOL
